Amana Heate/Air
My amana forced air heater/air conditioner will not start. It clicks a few times and then stops trying to start there is no flame. Thank You for your time. Ed
  • edfnelson Oct 25, 2008
    Thank you for your time jasond Ill give it a try
    Novelist:
  • 124 Answers
SOUNDS LIKE THE IGNITOR IS BAD OR NO GAS IS AVAILABLE.THREE ATTEMPTS TO LIGHT AND THE SAFTY SHUTS IT DOWN SO WE KNOW THERE IS A CALL. FORCED DRAFT IS RUNNING,AND AN ATTEMPT TO LIGHT IS OCCURRING. CHECK TO SEE IF 120 VOLTS IS BEING SENT TO THE IGNITOR IF IT IS AND IGNITOR IS NOT GLOWING THEN ITS BAD . R AND R EXACTLY AS FOUND. DONT TOUCH CERAMICS, WEAR COTTON CLEAN GLOVES .YOU ARE PROBABLY GOING TO HAVE TO PAY A PRO CAUSE THE PRTS ARE NOT GOING TO BE SOLD TO A HOME OWNER DUE TO THIS BEING A GAS FURNACE. A PRO WILL FIX , WARRANTY, AND TEST HEAT EXCHANGER, AND BE THERE INSURED IF THERE IS A PROBLEM.
Posted on Oct 25, 2008
Amana apn14j-e stops working after a few minutes
More likely the pipe sensor is defective (a sensor inside the evaporator ,connected to the thicker gas line).... if it don't send any temperature changes to the control board after 5 minutes , it believes the A/C isn't working and cuts off the whole thing to safeguard the compressor from damage ....
Apr 27, 2014 | Haier Amana Apn14j-E Portable Air...
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
My amana dryer turns on but wont heat only cold air
you can remove the acess panel fornthlower front, and the heate and thermostats are located on back wall, check for continuty, in hte thermnaostats and heater
Mar 15, 2009 | Amana DLE330RAW Electric Dryer
Squeaking in home heater
sounds like bad fan motor bearings
Jan 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
I have an amana air command 90 furnace. the burner won't light.
This unit goes in steps, 1-- thru--4 Step 1, vent fan blower motor runs & prove thru the air tube, which closes a switch and tells the circuit board to go to step---2 Step 2 lights the glow plug and goes to step 3 automatically, Step 3, opens the gas valve and send in gas thru the long venturi tubes which lights from the glow plug and on the last tube, theres a rod that sticks into the flame, if no flame or not working properly, it will shut down the starting sequences and retry for 4-times and automaticaly lockout till unplug and start over. (whever step it stops at, then thats where your problem is!
Sep 06, 2008 | Amana Heating & Cooling
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
