Question about Exercise & Fitness
Golds gym crosswalk 650 not working
The motor is running and the belt turns but as soon as you try to walk on it the belt stops turning completly and feels like it is sliding.
    Top Expert:
  • 12,223 Answers
Dear Sir:
The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
See the block diagram that i did design for easy troubleshooting and diagnose.
golds gym crosswalk 650 not working - 2_15_2012_4_24_13_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 15, 2012
3 Suggested Answers
  • 10865 Answers
SOURCE: Gold's Gym Crosswalk 650 Treadmill belt stops
Hello. Either there is too much load for the motor, or the motor is weak, or the controller in failing and unable to adjust for changes in resistance.
By far the most common problem is too much load. Do the checks in your manual to be sure the walk belt is not too tight or dry. Also check that the motor belt is not too tight, you should be able to twist it 90 degrees. If you loosen both belts until they just begin to slip and then retest you might find the everything is okay which indicates the walk belt may need lubing or replacing. If the walk board under belt looks pitted, grooved, or distorted it also would need replacing.
If the unit passes the tests above and a push test then the problem will be in the motor or controller or possibly both. If the motor passes a walk/voltage output test then it might be okay and you might only need a controller. Unfortunately, it is common for a failed motor to damage a controller and vice versa, and that damage might not show up immediately, so you if one has failed you might consider replacing both.
Posted on Mar 22, 2010
  • 9 Answers
SOURCE: good evening, hope all is
if the motor is still turning and the belt is not moving then you have two things it could be.
1. the walking belt needs to be tightened by adjusting the bolts at the rear of the machine for the rear roller (equal turns for both)
2. the drive belt is no longer tight or has come off and may need readjusted
did you open the front end to look inside yet? i am willing to bet that if you check these both out you should get it solved since the motor still runs
Posted on Aug 05, 2010
My Golds Gym trainer 480 treadmill minimum speed is 3 miles at lowest setting and it will not slow down when pressing the down arrow
Gold's Gym Treadmill Product Support ' ManualsOnline.com
fitness.manualsonline.com/support/golds-gym/treadmill/
My goldsgym treadmill just goes up and down when t. Gold's Gym ... my treadmill walking belt will not turn. ... Golds gym trainer 480 start button stopped working.
Repair Your Own Treadmill With Mark Peterson - YouTube
? 1:16
https://www.youtube.com/watch?v=B997gX07hW4
May 6, 2008 - Uploaded by Mark Peterson
A certified Fitness Specialist by the cooper clinic in Dallas, and a personal trainer for the first 16 years of my fitness career. .... I purchased a used Golds Gym Treadmill model# GGTL396100 which I tested when buying ... The treadmill will fully incline thennot go down, I have tried to recalibrate the incline ..
Nov 26, 2015 | Exercise & Fitness
My proform crosswalk 525x runs for about 2mins
Need a new walking belt, turn off the treadmill and push the walking belt with your feet and you are going to feel how hard it is with friction on the belt and deck. I f it is to hard you need to replace the walking belt.
You can order on www.walkingbelts.com
Sep 26, 2014 | Exercise & Fitness
Maintenance
the walking belt needs to be lubed with a good silicone lubricant. this is put under the walking belt
Aug 21, 2014 | Golds Gym MAXX CROSSWALK 650 TREADMILL...
Rear roller makes noise
most likely the bearings are going bad.try loosing the walking belt and rotate the roller by hand. if you feel any grinding or its not smooth it shoud be replaced. normally only the two adjusting bolts hold it in there
Apr 19, 2014 | Golds Gym MAXX Crosswalk 650 Treadmill...
Golds Gym Treadmill motor will not start after sitting idle for about a year
see the video and fix it. However after you did this and the problem remain, you must test a) control board or b) replace the old board deck belt.
Mar 24, 2013 | Golds Gym 450 Treadmill Drive Motor
IFit control Panel on Gold's Gym Crosswalk 570
go to the web site they a LOT of tool +software update for you ifit
http://support.ifit.com/home
God bless you
Feb 07, 2013 | Golds Gym CrossWalk 570 Treadmill
Good evening, hope all is well with the experts! here is the problem with my golds gym maxx crosswalk 650 treadmill. the walking belt will not move, however the motor still runs. help, i need to get back...
Aug 05, 2010 | Exercise & Fitness
While trying to run the mat/track stops or studders momentarily.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 10, 2010 | Proform Crosswalk 500 Treadmill
Gold's Gym Crosswalk 650 Treadmill belt stops if i am on it, but If i get off it runs fine. How do I fix this?
Mar 22, 2010 | Exercise & Fitness
Exercise & Fitness Logo
163 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
