Question about LG Televison & Video
Access netcast with no button
I got a replacement remote and it does not have the netcast button on it. How do I access netcast without the button. Is there a backdoor?
How can i hook up a dvd player to a Sylvain tv with no remote
Ok the brand of the tv is not as relevant as the particular model number as each set varies. generically speaking without having to ask you for more information, some tv set allow you to access auxiliary inputs without a remote by pressing a combination of buttons or repeatedly pressing the channel up or down button until the inputs are cycled. A lot of set also allow you to navigate through inputs by the menu, a menu is often accessible by buttons on the set. If none of these options are avaliable try contacting your tv manufactor and asking how to navigate the inputs Witout the remote, which keep in mind is highly possible that you may not be able to do so. Consider replacing the remote with a universal remote.
good luck and thanks
Questions? Just ask! Mr.Mike
Nov 17, 2015 | Televison & Video
Tip
How to Bypass BIOS Passwords
BIOS passwords can add an extra layer of security for desktop and laptop computers. They are used to either prevent a user from changing the BIOS settings or to prevent the PC from booting without a password. Unfortunately, BIOS passwords can also be a liability if a user forgets their password, or changes the password to intentionally lock out the corporate IT department. Sending the unit back to the manufacturer to have the BIOS reset can be expensive and is usually not covered in the warranty. Never fear, all is not lost. There are a few known backdoors and other tricks of the trade that can be used to bypass or reset the BIOS v Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself. They include:
Using a manufacturers backdoor password to access the BIOS
Use password cracking software
Reset the CMOS using the jumpers or solder beads.
Removing the CMOS battery for at least 10 minutes
Overloading the keyboard buffer
Using a professional service
Please remember that most BIOS passwords do not protect the hard drive, so if you need to recover the data, simply remove the hard drive and install it in an identical system, or configure it as a slave drive in an existing system. The exception to this are laptops, especially IBM Thinkpads, which silently lock the hard drive if the supervisor password is enabled. If the supervisor password is reset without resetting the and hard drive as well, you will be unable to access the data on the drive.
----------------------------------------------------------------------------------------------------------- Backdoor passwords
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops.
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords
Award BIOS backdoor passwords:
ALFAROME ALLy aLLy aLLY ALLY aPAf _award AWARD_SW AWARD?SW AWARD SW AWARD PW AWKWARD awkward BIOSTAR CONCAT CONDO Condo d8on djonet HLT J64 J256 J262 j332 j322 KDD Lkwpeter LKWPETER PINT pint SER SKY_FOX SYXZ syxz shift + syxz TTPTHA ZAAADA ZBAAACA ZJAAADC 01322222 589589 589721 595595 598598
AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO
PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
MISC. COMMON PASSWORDS
ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
OTHER BIOS PASSWORDS BY MANUFACTURER
Manufacturer Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX TMC BIGO Toshiba Toshiba
TOSHIBA BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM APTIVA BIOS
Press both mouse buttons repeatedly during the boot ---------------------------------------------------------------------------------------------------------- --------------------------------------------------------------------------------
P
on Jun 25, 2010 | Computers & Internet
Can't access DVD setup menu
Without its original remote control, you can't access it all functions. Try to get one original one. Contact the authorized service center for Sony.
Jun 02, 2013 | Televison & Video
Need to tune a trinitron kv-28f65u to a terristrial signal with no remote control, i can access the tuning menu but without the remote cannot press to OK to start tuning. Are there any combination of...
there is only autotune button on the panel which means it programmes all findable channels in serial order. sorry to say there is no other way without remote commander.
Sep 11, 2011 | Sony KV-28FX60 28" TV
Everytime i open programs, messages like this appears: "The application or DLL C:\WINDOWS\SYSTEM32\dx8vb3232.dll is not a valid WIndows image. Please check against your installation...
You have a Backdoor Trojan present on your pc
A Backdoor is a software program that gives an attacker unauthorized access to a machine and the means for remotely controlling the machine without the user's knowledge. A Backdoor compromises system integrity by making changes to the system that allow it to by used by the attacker for malicious purposes unknown to the user.
They are typically installed without user interaction through security exploits, and may allow an attacker to remotely control the infected machine. Such risks may allow the attacker to install additional malware and use the compromised machine to participate in denial of service attacks, spamming, and bot nets, or to transmit sensitive data to a remote server. The malware may be cloaked and not visible to the user. These risks severely compromise the system by lowering security settings, installing 'backdoors,' infecting system files, or spreading to other networked machines.
If your computer was used for online banking or has credit card information on it, all passwords should be changed immediately to include those used for email, eBay and forums.
You should consider them to be compromised.
They should be changed by using a different computer and not the infected one,if not an attacker may get the new passwords and transaction information.
Banking and credit card institutions should be notified of the possible security breech.
Since your computer was compromised read:
How to report ID theft, fraud, drive-by installs, hijacking and malware:
http://www.dslreports.com/faq/10451
When Should I Format, How Should I Reinstall:
http://www.dslreports.com/faq/10063
Mar 11, 2011 | Computers & Internet
I have a LG 47Inch LE5400 LED TV and I'm trying to activate netflix. I can't find where on the tv options or the remote to access netflix? I don't see a netflix option anywhere.
On the LG remote, push the "netcast" button, which is between Menu and Q.Menu.
You need to have a Netcast account set up at Netcast.com
Jan 10, 2011 | LG 47LE5400 47 in. TV
Dead remote = no dvd access?
Try a RCA universal remote with an input button. Try the codes for Orion , Sansui and RCA. Access the menu by holding down both volume buttons on the front of the set. There is no access to the jacks on the front of the set without a remote. If all else fails get a RF Modulator. This will allow you to watch your dvd by using the antenna jack on the back of the set.
Aug 10, 2008 | Durabrand DU1301 TV
No Remote - Need to access Menu
on some sets you can push both the channel up and down buttons to access the menu, then use them and the volume buttons to navigate the menu. otherwise you may have to get a programmable remote control.
May 30, 2008 | Televison & Video
Televison & Video Logo
565 people viewed this question
Computer Repairing
Computer Repairing
