Question about Kicker SX900.4 Car Audio Amplifier
Amp how can i adjust my amp to my mids turns off every time i gets to loud ....trying to adjust properly without burning or blowing up my mids/tweeters
  • che_leah Oct 25, 2008
  • 4 Answers
Hook up a cross over to ur amp this way it will not let the mids/twets blow
Posted on Oct 25, 2008
Can anyone help
What size is the amp and how many watts is the speaker(s) you have it ran too? If your speakers are trying to pull too much power from the amp it will turn itself into protect mode to keep from blowing a fuse as well as if you are pushing to many watts into small small speakers it will do the same to protect from blowing the speakers I would recommend turning the settings on the amp down slightly and then trying it out also make sure your wires arnt crossed adjusting the setting as it plays is the easiest way to fix the problem also make sure the bass isn't all the way up on your head unit
Jul 12, 2013 | Car Audio & Video
I have a alpine type r 12 in a seald box and want to know how to adjust my amp to sound right with metal and rock
hard to do because it is a VERY loud sub. turn the frequency down low on the amp so as just to be able to hear the kickdrum and bass line and turn the gain up just loud enough where you can hear it comfortably ( to your taste) at the loudest volume your going to listen to it at. if you do it right itll sound good. if you turn gain up past half or more it might blow your sub so be careful.
Sep 12, 2011 | Hifonics BRZ17001D Car Amp
I just install my new setup ,i have 1 pdx f4 ,1 pdx m12 and 2 sub 10''type r and my pproblems is when i put a song the pdx f4 lights become red and my mid and tweeter cut ...
Disconnect all speaker leads from the PDXf4 - test. If the amp turns on and says on ok - then turn off, and attach one speaker lead at a time until it turns off. When it does check that speaker and the speaker wire to see if it is blown, shorted out etc.
Feb 06, 2011 | Alpine PDX-F4 Car Amp
My ma audio hk 898 will power on but will not push subs at all what can i do
Hello 76firebirdfo,
If there's no sound at all from the subs and you know they are good, there's probably no output from the amp. It's either wired incorrectly or it is defective.
If there's some sound but just not loud enough, then either the amp is not getting enough of an input signal from your head unit, or the amp settings are not adjusted properly. Adjust the crossover and gains for the best output to subs. LP filter on, crossover frequency at about 80-100Hz, and gain to maximum without distortion when head unit volume is at about 3/4 maximum.
Hope this helps.
Jul 14, 2009 | MA Audio Hard Kore HK-898 Car Audio...
I have an alpine head unit and a kenwood 1000 watt amp. I have two 12" subwoofers hooked up to the amp and thats it. I got my tweeters, and door speakers powered by my head unit. The bass was cutting in...
your amp may have burned out or try checking the fuse in the amp and the car also your channels may be burned or you may jus have water damage to the amp
Feb 18, 2009 | Kenwood KAC-7202 Car Audio Amplifier
2 12w6v2's with a 1000/1
I dont know how you blew both subs with a 1000/1. the subs have an rms of about 400w. according to jl,the sweet spot for them is about 500-600watts. are you sure that you had the jumpers wired correctly and the amp at 2ohms?
Jun 11, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Fuses
Check the ohm measurement of the speakers make sure they are about the rated ohms.Check them UNHOOKED from the amp. (Useually 4 ohms.)
Try different subs.
May 25, 2008 | MTX Thunder 3401 Car Audio Amplifier
Autotek amp
You got riped off if i were you i would go and get my money back because an amp like that cost around 399 to 499 dolars
Jan 24, 2008 | Autotek MX800.4 Car Audio Amplifier
Fuses
Hi, when the fuses blow it can only mean that the current the passed thru it is greater than its rating. It is possible that the fuses installed has a lower rating than is required by your amp. To check look over the specs of your amp and determine the proper amperage (amp) rating. Specs may be found on a sticker at the bottom or side of the amp and may look something like 12V-20A meaning 12 volts 20 amperes. In the absence, you may want to check the box and/or the instructional manual that came with it ot go to the manufacturer's website to checkout the specs. If you are referring to the fuse serving all your amps, players, receivers, etc, then you have to addup all their individual A rating and get a fuse whose rating is equal to the addedup value. Although this is not a sound practice and individual fusing is preferable. If the amp rating is equal to the fuse rating but it still blows, then you may want to have your amp checked. Trying to install a higher rating will most likely prevent fuses blowing and present itself as a temporary solution but the real problem is not solved and may be aggravated. Hope this be of some help and good luck.
Apr 22, 2007 | Lanzar VIBE286 Car Audio Amplifier
Kicker SX900.4 Car Audio Amplifier Logo
56 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
