Question about Gaggia Baby Espresso Machine
Gaggia baby dose d (circa 2007) wont dispense water? pump?
Hi to all.
i have a baby dose d bought only a year ago,2007
everything starts fine the steamer works fine.but when i press icon for cup of coffee,the icon then flashes?the pump sound starts (rather noisey?) after around 40 sec(sometimes a minute) the pump noise stops.
i have clean all parts (except ive not opened up the machine eg the inside)
if the staemer works does that mean the pump is ok?
please help someone as this machine has had only light use(out of warrenty) cant believe its broken already?
kid regards
geoff.
london . uk
  • funkyguy Oct 30, 2008
    thanks for your advise,
    much valued.
    geoff
Sounds like it needs descaling - not the normal descaling but inside the pump head!
Posted on Oct 30, 2008
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
Baby Gaggia Dose leaks
On the gaggia clascic there are 2 hoses in the back above the drain tray, are those in the water reservoir? If yes then there is a broken hose on the in side of the machine.
Aug 12, 2009 | Gaggia Baby Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
Gaggia baby dose solenoid valve
You may get this part from EBay for around $45/£38 a small "How to" below ">
Dec 04, 2008 | Gaggia Baby Espresso Machine
Leaking water
It sounds like the main valve is faulty. Replacements are available or you may be able to dissasemble it and replace the seal.
Hope this helps.
Sep 04, 2008 | Gaggia Baby Espresso Machine
Gaggia Espresso Machine bought about 10 years ago
  1. if it is fine ground coffee sometimes you get this result at machines.
  2. low pressure pump = you get water from it but only when handle is out or steam valve open.
  3. pump with non return valve broken = in this case you get water if you open tea valve during pump works. this pump can work long even she has 1 valve damaged, only when she is empty you need to open steam valve and leave pump running while you don't get water from valve.
Feb 15, 2008 | Gaggia Espresso De Luxe Espresso Machine
Gaggia Baby Espresso Machine Logo
556 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
