Question about Panasonic KX-TGA650B 5.8GHz 2 Line Expandable Handset for the KX-TG6500 Series 037988474806 Phone
Deregister used panasonic handset without base
On another working handset do the following;
Menu #131
Scroll and select the handset you want to deregister
Confirm you want to deregister
"Deregister" screen will display and handset will be deregistered
Posted on Feb 05, 2016
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Posted on Feb 17, 2008
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
SOURCE: DeRegistering a Damaged Cordless Phone???!!!!
Here is the procedure as given to me by Panasonic Tech Support.
To DEREGISTER, using the handset you want to register, push MENU.....002.......335...and hit ok.
Then press the handset number you want to deregister (1 through 4). Don't worry if the handset says there is no link to base. This is because you just unregistered it so there will be no link.
To REGISTER, press and hold the locator button on the base unit until the green LED starts blinking. Then take the handset unit and press MENU.......001 and hit ok. Your unit should now be registered.
Posted on Feb 16, 2009
How do I deregister an orphaned Vtech sb67108 handset to use on another bases without the original base
Here are the steps: Press menu, then press *883247# and then press the up arrow. Select deregister and then unplug and take the battery out for 10 seconds. Plug the phone back in and it's ready to be registered to another device.
Oct 06, 2014 | VTech Communications 4-Line Cordless...
How do I unregister a lost handset for a Panasonic phone kx-tg5576
Since you do not have the phone anymore, obviously you cannot use it to deregister it! So here is what you do: One the base unit, Press and hold {INTERCOM} until the CHARGE
indicator flashes, then (2) Press and hold the handset's
extension number {1} to {8} that you do not want for 5
seconds. A long beep sounds, then the handset
number is erased. This will deregister that number handset unit.
Sep 23, 2014 | Panasonic Phones KX-TG5571
I need to deregister a DS6101 without the base. I needed to replace the base and once we installed the new base, the extra handset that we had registered with our old base shows the following message...
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
Feb 16, 2011 | Vtech DS6101 19 GHz Cordless Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
Nov 19, 2009 | Panasonic KX TGA270S Cordless Expansion...
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Nov 05, 2007 | Panasonic KX-TG6074B Phone
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Lands Phones Logo
725 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
