Question about Toys
How to get replacement cards for pooh vtech picture computer
Do vtech kiddizoom cameras work without the 2gb memory card?
Yes, the camera will work without a memory card. However, having a memory card will allow you (or your kid) to take a lot more pictures. It's also easier and faster to download pictures to your computer from a card than from the camera.
Feb 20, 2013 | Cameras
Downloading picture from camera to computer
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Aug 01, 2012 | Vtech Kidizoom Digital Camera
Vtech storio in touchscreen calibration mode
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
Dec 28, 2011 | Vtech V.Reader Interactive Reading System
How do I empty the photos onto my computer? when I plug in the camera nothinh appens
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Jun 09, 2010 | Vtech Kidizoom Digital Camera
I need help I can't get my pictures to save on the computer.Help?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
May 29, 2009 | Vtech Kidizoom Digital Camera
How do you get to the photo album???????
Connect the usb cable between the camera and the computer. Make sure the camer is off. After you connect the camera to the computer, then you can turn on the cameral. Go to My computer and you will see all the drives. Look for VTech 773. Double click on the drive and you will see a PHOTO folder, pictures will be there. Remember: if your using an SD card, then you will see that under removable drives. Your pictures could be there too.
Feb 16, 2009 | Vtech Kidizoom Digital Camera
CANNOT DOWNLOAD
There is no software for the computer to recognize and it will not download to your computer automatically. This is what you do: After connecting the usb cable from the camera to your computer, go into my computer and look for the drive, it will probably show up under removable drives. Can you see the drive VTech 733 there? If so, double click on the drive to open it and find the folder named Photos. Your picture should be there.
Jan 30, 2009 | Vtech Kidizoom Digital Camera
Can't download photos to computer
I figured it out and boy do I feel dumb. If you have an SD card installed in the camera, there are actually two drives when you open "My Computer" - one is "VTech773", which is the internal memory and the other is "Removable Disk", which is the SD card. If your camera has an SD card and it is set up as the default storage option, then the pictures and videos are located in the "Removable Disk" drive. Here's the text from the owner's manual...
You can connect Kidizoom Camera™ to a PC using the included USB cable. Once connected, you can upload and download files to Kidizoom Camera™ by accessing your camera as a removable storage device. When Kidizoom Camera™ is connected to the PC, a new drive called “VTech 773” will appear on the PC. If there is also an SD memory card (not included) inserted into the camera when it is connected, two new drives will appear. One will be the “VTech 773” drive and the other will be a removable disk drive for the SD memory card.
http://www.vtechkids.com/_f/_pw/_manual/80-077300%20Kidizoom%20Camera.pdf
Jan 28, 2009 | Vtech Kidizoom Digital Camera
My pictures need to come off my camrea
This will do it for you. Connect the usb cable between the camera and the computer. Make sure the camera is off. After you connect the camera to the computer, then you can turn on the camera. Go to My computer on your pc and you will see all the drives. Look for VTech 773. Double click on the drive and you will see a PHOTO folder, pictures will be there. Remember: if your using an SD card with the camera, then you will see that drive listed under removable drives. Your pictures could be there too. Let me know if that helps.
Rob
Dec 18, 2008 | Vtech Kidizoom Digital Camera
Toys Logo
82 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
