Question about Hisense Televison & Video
Our 40' hisense tv keeps blinking sometimes it goes for an hour or two without and sometimes it blinks continuously
  • 1 more comment
  • Anonymous Mar 30, 2014
    when watching it flickers or blinks
    when watching it will blink
    when watching it will blink or flicker
I'm posting this to help anyone who might run across one of these tv's with 7 blinks then 3 blinks. I replaced the power supply board and the tcon board. Narrowed down it's the main board (Green board with all the wires) Did some digging seems like there is an eeprom that goes bad and causes the issue. You can buy the eeprom off ebay for $15 for some models but for the model i have 50k360g i believe it's eeprom e9. Not sure...going to just but the whole board off ebay and hope for the best. Do some research on google about the eeprom n8 and it gives you symptoms.
Posted on Jun 17, 2016
    Top Expert:
  • Hisense Master
  • 74,136 Answers
Hello
You haven't given the exact model number to your Hisense TV here. Yet, i posts this solution, as this is a common problems to all TV, irrespective of Brrand and model.
Check its power supply regulator board, for any loose solder points. Resolder all the suspected solder terminals to this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. You have to take the board out from the TV to do this job.
Reset it and see whether it helps you. If not, power retgulator board must be replaced as card basis. OK.
Posted on Feb 15, 2012
  • Thomas Rudd
    Thomas Rudd Dec 14, 2013
    Would giving the serial number help identify the problem? I'm computer savvy but motherboard/soldering stuff I'm not too trained on yet. The 40k360 was all I could find on the back of the TV. And there's a S/N but can't find exact model number
2 Suggested Answers
SuperTech-11
  • 1591 Answers
SOURCE: tv won't come sometimes with
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Capacitors are less than a buck a piece typically, and can be ordered online from places like www.digikey.com. They charge $8 for shipping, but the parts typically arrive next business day.
Posted on Jul 11, 2011
Hisense tv will only display the word hisense with no picture and power light continually blinks
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. http://electronicshelponline.blogspot.com/ If you wish to get more details visit the site linked here.
Feb 21, 2017 | Hisense Televison & Video
My hisense flat screen LED blacklight tv, model: LEDN32D20 can't just be turned on,whenever I turn it on its blinks continuously.... Is the any how I can use remote to sort such letter out?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Dec 23, 2016 | Hisense Televison & Video
HISENSE MODEL 46K360M Question WHEN TRYING TO TURN TV ON RED POWER LIGHT BLINKS CONTINUOUSLY AND NO PICTURE OR SOUND ALTHOUGH 1-IN-20 ATTEMPTS DOES POWER UP THE SET
Nov 25, 2016 | Hisense Televison & Video
My Hisense smart flat screen 50H5G won't turn on. I push the power button and it goes to stand by. I push the button again and the red light blinks 10 times and it shuts off.
Nov 22, 2016 | Hisense Televison & Video
We are having a problem with our new Hisense Roku TV ~ when turning it on, the red light in the lower right corner flashes as if it is going to come on, and it doesn't.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Nov 05, 2016 | Hisense Televison & Video
My Hisense 50K23DG T.V. wont turn on?
Aug 22, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
Hi, I have Hisense 50K23DG. It has no sound, no picture and 5 and half or as 6 red blinkings. Do you know any error code for this Hisense?
Apr 20, 2016 | Hisense Televison & Video
Have Hisense tv that keeps resting itself red light blinks four times and rests itself again over and over. I have replaced main board still does it.
Mar 29, 2016 | Hisense Televison & Video
I have a hisense 50 inch tv, when I turn it on the brand name and the red light just blinks until I turn it back on. What does that mean and what do I do?
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 07, 2015 | Hisense Televison & Video
My lcd tv the screen flashes like blinks when the background is a light color like an icesurface
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 10, 2014 | Televison & Video
Televison & Video Logo
2,970 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
