Service to repair pcb module hoover optima washing machine
Drum does not spin at speed
    Sergeant:
    Champion:
  • 245 Answers
Two screws on the back. Lift the cover off. Pull out dispenser, push middle tab. Pull out. Two screws on the dispenser. 2 screws on the top of the control panel. Take a pic with your cellphone at the wires. Replace and reverse.
Posted on Feb 15, 2012
4 Suggested Answers
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
  • 3 Answers
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
Posted on Nov 05, 2009
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
What is error code F11 ?
An E11 error code indicated there's an open circuit on the dryer heater or a module issue it's a good idea to check the wiring from the sensor on the top the drum to the circuit board as this can become damaged during the spin cycle.
Nov 24, 2014 | Hoover Optima 7 OPH716DF White 600 mm...
Hoover 750 lc heavy duty macking noise whene spinning dry
Possible drum bearing. Check for any knocking by turning drum by hand whilst empty.
Sep 13, 2014 | Hoover Washing Machines
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
A knocking sound when it spins
what is the drum doing whan you start the washer with the drum
Jan 22, 2013 | Hoover Washing Machines
Nextra6.will only go on 40min wash and only spin on slow spin. checked motor brushes and there fine. is it the circuit board
I have a hoover optima 1400AAA, it began to give trouble with programs, 40 degrees washed at 80 degrees, would not spin or empty, etc, called in a hoover repair man who cost me 120euros to remove the program knob and spray the contacts with Servisol super 10 switch cleaning lubricant, apart from the fact that I am still furious, everyone who has a hoover washing machine should know this.
Mar 21, 2012 | Hoover Nextra HNL 3166 Z Front Load Washer
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover washing machine HF7160E
I am a recently retired appliance engineer of 20 years, and this at first sounds like motor carbons, the belt needs to be placed on from the bottom motor pulley first the onto the drum pulley last, not easy to describe in words, anyway start with the carbons, then if they ok there is a module (main PCB circuit board) normally on Hoover washes located top of machine inside front right corner in a plastic casing, look for burn marks. work safe with electrics, always unplug first
Sep 09, 2007 | Hoover HF7 160E Front Load Washer
Intermittant Drum
is the a pcb near the motor,sometimes the motor controler board can be faulty not sure on this brand hope this helps.
Sep 22, 2006 | Hoover HW130M Front Load Washer / Dryer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
