Question about GE DVLR223 Dryers
How to remove the front panel on ge dryer dvl223
  • 8 Answers
SOURCE: ge dryer model# dvl223
This may sound silly but did you check (or have the means to check) for voltage at the outlet? The absolute bottom line is that if there is no power.......you get the rest.
Posted on Jul 28, 2008
  • 111 Answers
SOURCE: back panel removal
Do NOT even try to remove the back panel. It is more complicated than it looks. You would be better off to pull the door jamb off the house... not trying to be funny just serious!
Posted on Dec 18, 2008
  • 207 Answers
SOURCE: How to get the front panel off GE Profile Harmony
Here's a simple overview of what you have to do:
You actually don't remove the back sir, but that's okay, that's a common misconception for this model dryer. The proper way to disassemble this particular dryer is you start with the top. You have to start with the removal of the control panel, then the top of the dryer. What I would consider the top cover. Then you'll have to remove two plastic brackets. Then you have to remove the front. There's two aluminum brackets in each corner, remove those. Open the door and there'll be two more screws to remove on each side. You have to lift the front just a little and then pull towards you. I forgot to mention, before that part, you'll need to ensure you are disconnecting the electrical wiring. There's almost no chance of connecting the wrong ones even if you forget. GE made this part novice proof. Once you get the front removed, you'll see the lint/trap. There's a couple of screws on either side of the aluminum housing. Not much to it. Let me know if there's anything I can clarify further. Have fun!
Posted on Apr 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: I HAVE GE DRYER MODEL DVL223 AND THE DRUM SEEMS
You need to replace the bearing and glides.
(MORE)
Posted on Jul 06, 2009
  • 180 Answers
SOURCE: my ge gas dryer glides I suspect are bad model #
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Dryer-Parts/General-Electric-Parts-NVL333GY0WW/General-Electric-Parts-58994.cfm
Shows a picture of the lid of your dryer. #7are the clips that hold the lid down. Locate them then use a flathead screwdriver to release them.
Posted on Oct 25, 2009
Testimonial: "thank you very much"
Remove front panel ge spacemaker dryer
Here's the trick: The Spacemaker dryer is the same as many other GE dryers but is upside down!
1. Unplug the dryer.
2. Flip the dryer upside down so the white panel is now on top and the unfinished steel panel is on the bottom.
3. Remove the 2 screws that connect the bottom, white panel from the back and lift up to remove.
4. Pull off the Settings and Fabric knobs on the front of the dryer. Take off the front control panel (remove the 2 screws).
5. Remove the 2 screws that attach the front panel (located behind the control panel you just removed). Hold the dryer drum by the top edge and pull the front panel away (note that the panel will be hooked to the rest of the dryer at the bottom corners). DO NOT PULL AWAY ENTIRELY!
6. Disconnect the wiring that is attached to the front panel (these come apart easily by hand but you might want to mark the wiring so you know where to connect it when reassembling).
Apr 05, 2012 | GE Spacemaker DSKS433EB Electric Dryer
My Electric GE DVL223 dryer stopped drying. There is no heat but the timer does work down
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 25, 2011 | Dryers
Model DVL223 GE dryer buzzes / hums when the start button is turned, but does not start or turn the tumbler tumbler moves freely by hand from inside
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2010 | GE DVL223EBWW Electric Dryer
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
How do I replace the felt seal on a DVL223 clothes dryer?
There are usually some torxes screws underneath the top of the dryer. They need to be removed. Then there are a couple of bolts at the bottom, they normally don't have to be taken all the way out, just loosened. and there should be a couple of bolts inside for the front assemble...unplug the door switch, lift up on the door and just move it aside. Don't move the drum around too much since it shouldn't have to be removed...the felt is normally attached to the door is should be replaced the same way you remove the old one. A good time to look at the wear on your slippers, which are really plastic glides for the dum to run smoothly on, but they are right there, and if they need replaced, the job would be simple at this point and cheap.
Oct 19, 2009 | GE DVLR223 Dryers
Dryer Drum bearing designs
these drum glides look cheap,but they last for a long time
Jul 26, 2009 | GE DVLR223 Dryers
Ge dryer model# dvl223
Jul 27, 2008 | GE DBSR453EBWW Electric Dryer
GE DVLR223 Dryers Logo
137 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
