Question about LG LDF6810 Built-in Dishwasher
LG Full size silver Dishwasher Model : LD2060SH has error code e1 no leaks anywere can you help please?
IF THERES NO WATER COMING IN REPLACE POWER BOARD
Posted on Oct 25, 2008
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
What can I do for an E1 code?
Hi liyoung,
The full description on what to do is located in my Tip below:
Hope it helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it.
Jul 19, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
I get the E1 code a few minutes after I start the dishwasher. Am I able to do something or do I need a repair person?
Hi liyoung,
Hope it helps :-)
JEDEMEYER1
My dishwasher LDF6810ST is showing an error code E1- I tried the checks that fixya gave me - there are no leaks. I called customer service and he said I would need a repair man. Please refund my money
Hi ardyhansen,
Please check my tip on a solution for this precise error, hope it helps:
CLICK HERE -> L.G DISHWASHER E1 ERROR
Kind Regards :-)
Jul 09, 2011 | LG LDF6810ST Stainless Steel Built-in...
The machine takes water and a minute later empties it out again with an error code E1. I opened it to see if any leaks anywhere as the diagnostic page puts this down to leaking pipe, but no leak found...
Hi salim talati,
The E1 you are seeing means Water Level in Drum lowering, this is likely a reduction in speed of the impeller on the Circulation Pump, which is responsible for pushing the water to the Spray arms.
It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending which one is in stock)
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote for it
Jun 15, 2011 | Dishwashers
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
Hi there I have a silver LG dishwasher..I am intermittentleey getting the Code PE. I have take the pump off the exit water pipe and chaeck for blockages etc... there are none. Any ideas?
Please confirm the model number of this LG diswasher.
On recent LG units, the avaiable error codes are: IE OE E1 FE tE LE
The PE code is abnormal. Can you confirm.
I would expect to see the error OE if water is not fully pumped out. Remove the filter from the sump area beneath the bottom rack. Look closely for debris causing a blockage/lock. Please get back to me with your findings and ask more questions as needed.
Jan 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
I have error code e1
Hi. Sorry this is so late, but I just happened across this post, so I thought I'd see if you have solved your problem yet. The EI code most often is caused by water leaving the tub during the wash cycle. The most common cause of this is that the dishwasher drain hose does not have a high loop in it. Often, the installer ran the hose right down through the floor. It needs to loop up high before going to the drain to prevent water loss, and a resulting IE code.
Oct 25, 2008 | LG LDF6810 Built-in Dishwasher
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Sep 20, 2007 | Dishwashers
LG LDF6810 Built-in Dishwasher Logo
288 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
