Question about LG LDF6810 Built-in Dishwasher
I have error code e1
Hi, i have e1 error code there is no leaks anywere i have had the dishwasher in the car on its side cos i moved so maybe thought it mite need time to settle left it over night and still getting same error code can anyone help please?
  • dkinnee Jan 13, 2009
    When we start the washer no water enters and in approx. 30 seconds you here numerous beebs. when I open the door there is an E1 error flashing. No water has entered the dishwasher.The water supply line is okay and turned on.
  • 1,543 Answers
Hi. Sorry this is so late, but I just happened across this post, so I thought I'd see if you have solved your problem yet. The EI code most often is caused by water leaving the tub during the wash cycle. The most common cause of this is that the dishwasher drain hose does not have a high loop in it. Often, the installer ran the hose right down through the floor. It needs to loop up high before going to the drain to prevent water loss, and a resulting IE code.
Posted on Nov 20, 2008
Error code E1
Hello simonhall900 - Typically error code E1 indicates that the unit has detected a leak. At this point, I highly recommend connecting with a professional to accurately diagnosis the leak and to properly assist with the repair(s).
Mar 01, 2013 | Electrolux WT30H240DU Dishwasher
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
My dishwasher LDF6810ST is showing an error code E1- I tried the checks that fixya gave me - there are no leaks. I called customer service and he said I would need a repair man. Please refund my money
Hi ardyhansen,
Please check my tip on a solution for this precise error, hope it helps:
CLICK HERE -> L.G DISHWASHER E1 ERROR
Kind Regards :-)
* If you found this solution helpful, please rate it
Jul 09, 2011 | LG LDF6810ST Stainless Steel Built-in...
LG Model 67LDO210 Error E1
Hi, the "E1" error code means the dishwasher has developed a leak. Meaning your outlet hose is too low or too far down the drain, it is losing water while it is washing making it think there is a leak...
Jan 16, 2011 | Dishwashers
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
"E1" problem
I would request you to please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Hope this helps resolve the issue.
God Bless
Jul 09, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg dishwasher lds 5811st E1 error code
Hi Chaz,
The impeller breaks on the motor shaft. The motor still turns, but the impeller doesn't, so it doesn't pump water. Because the machine senses there is no water pressure from the pump, it shuts down & displays E1 (it thinks there's a water leak, due to no pressure)
Unfortunately the motor/impeller is only available as a complete assembly
Hope this helps
Col
Dec 11, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Dec 18, 2007 | Dishwashers
E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Oct 14, 2007 | Whirlpool 24 in. DU940QWD Built-in...
LG LDF6810 Built-in Dishwasher Logo
328 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
