Question about JVC AV-27020 TV
Intermittent problem with JVC AV-27020 CRT TV. Power indicator light blinking with no picture or sound. When I unplug it, open the back cover and randomly touch and feel the components inside, plug it back in and turn it on, it works for a few days. Then again same problem. Please help. Thanks.
techman
  • 3130 Answers
SOURCE: JVC AV-27020 TV Blinking LED, Static Electricity on tube but no sound and image
Sounds like a bad main regulator IC.. Try putting a 100 watt light bulb across the main AC fuse, turn on the set and see if it will stay on longer. If it does, replace the main regulator iC. If it does not, then it could be almost anything in the sweep section of the set, and or in the regulation circuit of the power supply. Look for slightly swollen capacitors in the set. good Luck please do not forget to rate this thread.
Posted on Dec 10, 2006
  • 93 Answers
in jvc av-27020 we called that problem as on timer.your red LED indicator blinking.the reason is your vertical ic is defective if your vertical ic is la7832 replace it with la7840 if there is no la7832.that is most common cause of blinking in jvc 27020
Posted on Oct 18, 2007
freetek
  • 5568 Answers
SOURCE: JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Posted on Aug 23, 2008
SOURCE: JVC AV-35750 TV
I changed capacitor C926 (1000Uf 16V) on main board. It solved the problem. I went with 1000uF 63V as it was readily available...it's okay to go with higher voltage. It was hard to fit it on because of the larger size but it worked.
Posted on Dec 07, 2008
romsky79
  • 822 Answers
SOURCE: When I turn the TV power on, the TV picture won't display, but the timer display (red blinking light) blinks momentarily and then clicks off. What is the problem and how much would it cost to have rep
check the horinzontal out transistors. call qualified personnel to fix.
Posted on May 30, 2009
How do you stop tv light from blinking in the front?
do you mean the power indicator in the front panel is blinking?, ok does the tv working with picture and sound? if not working you can not get to stop the blinking since it tells that has an error detected by the board.
Oct 02, 2012 | JVC AV-32S33 32" TV
I was playing a game and it made a sound then shut off now my on timer light is blinking. when i unplug and plug back in the timer light stops blinking for a second then starts again.
Something shorted in the set, possibly the horizontal output transistor or a power supply diode. The reason it starts blinking again after plug in is because JVC try to come back on if they were on when the problem started. In other words, if it quit while it was playing it will always be in the on position until the problem is repaired and it can be turned off normally. Have a shop check it out for you. There are a lot of things that can cause one to go out. Thanks
Nov 01, 2009 | JVC AV-27020 TV
JVC PROJECTOR TV 61INCH
try to checked the memory program I.C. located near the controler I.C. or it maybe put you on timer mode, try to go menu and checked the settings
Jul 30, 2009 | JVC AV-27020 TV
Blinking Timer Button
The tv must of turned on the timer by itself. They do do that sometimes. I suggest leaving it unplugged for 24 hours to reset itself.
If problem persists, you may be able to go to your menu and access the sleep mode timer and set it to 0:00 or OFF
Jul 10, 2009 | JVC AV-27020 TV
The on light is blinking but there is no picture or sound.
I have the same problem with my JVC AV27750, the problem is probably the power supply relay circuit, just check and replace the 1000uf capacitor
Jul 06, 2009 | JVC AV-36260 TV
The timer on button flashes
The timer light blinking indicates a failure in the TV set. Either the vertical circuit or horizontal circuit has failed and needs repair. It actually has nothing to do with the timer circuit.
In my experience its probably a vertical output chip, smalla capacitor and zener diode. There may also be an open resistor.
Cost to repair in the 50-75 dollar range usually
Feb 24, 2009 | JVC AV-27020 TV
Digital Tuner or Analog
I have the JVC AV-27020 and had to download the manual just today. I checked where I got my manual and they did not have anything for an ACV-27020. The link for the TV manual I downloaded is below. Maybe it will help.
http://www.retrevo.com/s/JVC-AV-27020-TVs-review-manual/id/279ag501/t/1-2/
Aug 10, 2008 | JVC AV-27020 TV
Dec 10, 2006 | JVC AV-27020 TV
JVC AV-27020 TV Logo
128 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
