Question about Toshiba Satellite M115-S3094 Notebook
Bios update failed, computer will not start
I updated my bios and it failed during install. Computer shows AC power and hard drive lights but does not come on. Computer runs the fan and makes a soft clicking sound and that is all.
Prior to attempted bios update, it would not charge battery and showed 100% charge when battery was in fact dead. Toshiba offered a fix with bios update and that lead to this problem.
Can I fix this without having to replace motherboard?
  • Gerard Pereira
    Gerard Pereira Nov 21, 2008
    I have the same problem, which occurred after I flashed the BIOS on a Toshiba Satellite M115-S3094. Can I purchase a new BIOS chip and install it on the Motherboard or do I need to purchase a new motherboard? Motherboards seem hard to fine.... Thanks for your help.
  • ningreingam May 11, 2010
    how to replace the BIOS ?
Pankaj_dic,
Do you mean to replace the motherboard or the Bios? I assume you mean the motherboard.
I've been researching the possiblity of having a new bios chip put on the motherboard instead of the cost of a new motherboard (300+ install).
Thank you for the quick response.
Posted on Oct 25, 2008
    Genius:
  • Toshiba Master
  • 1,250 Answers
The bios of your motherboard has gone , replace it,
How to restore corrupted BIOS of presario cq60 laptop
Whenever you upgrade the BIOS on your notebook, a copy of the previous version is stored in the HP TOOLS partition of your hard disk drive. Many HP notebook computers have an emergency BIOS recovery feature that allows you to recover and install the last known good version of the BIOS from the hard drive, as long as the hard drive remains functional. This emergency recovery feature is separate from the BIOS and is designed to work in the event of a catastrophic BIOS failure.To recover an earlier version of the BIOS on your notebook:
  1. Turn off the computer.
  2. Plug the notebook into power using the power adapter.
  3. Press and hold the Windows key and the B key down at the same time while the computer is off.
  4. Still pressing those keys, press and hold down the Power button on the notebook for 3 seconds and then release the Power button and the keys. The screen remains blank for about 40 seconds before anything appears on the display. You might also hear beeping sounds. Eventually, an HP BIOS Update screen displays.note.pngNOTE:If the computer fails to display an HP BIOS Update screen, press and hold the Power button for 5 seconds to turn off the computer. Wait 5 seconds and try again. If, after repeated attempts, you cannot open the HP BIOS Update screen, your computer does not support this function or it has a hardware problem that is preventing the tool from opening.Figure 1: HP BIOS Update screenc03376208.jpg
  5. When the BIOS has been recovered, a Continue Startup button displays and timer counts down. You can click Continue Startup to restart the computer or you can allow the timer to reach zero and the computer will restart automatically.Figure 2: HP BIOS Update screenc03376209.jpg
  6. After restoring the BIOS, if the computer repeatedly displays a message that the BIOS has been reset, then perform the steps in HP BIOS Application Selected is Corrupt or Missing .
  7. After restarting, Windows may display a message stating that the computer was improperly shut down or that a boot problem was detected. Read and respond to the screens to continue.
Sep 22, 2012 | Maxtor Personal Storage 3200 (U01E200) 200...
Bios Beep
Motherboard BIOS Recovery Jumper
  • Install the bootable BIOS upgrade disk which you previously created to do the original flash upgrade into drive A: and restart the system. If the update failed because you used the wrong BIOS update you should get the correct one and repeat this step. When the computer reboots there will most likely be no video prompts, however you can monitor this procedure using the floppy drive light and the PC speaker. When the PC speaker beeps and the floppy drive light is lit it means that it is currently copying the new BIOS onto the motherboard.
  • When the floppy drive light goes off and the PC speaker beeps (twice in most cases) the recovery should be complete. During the update procedure there might be pauses that looks like your computer is doing nothing, if so be sure to wait at least a minute to make sure the update is complete. When you are sure the BIOS update is complete and there is no more activity, power off the computer.
  • Change the jumper you changed before back into the original position so the computer can operate normally.
When you turn your computer back on your BIOS will be functional and you should be able to use your computer normally again.
Apr 30, 2012 | Acer VL460-UD4500C WINDOWS VISTA BUSINESS...
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    Acer aspire turns on but nothing on the screen
    Hi;
    This happened to me twice ( got two net books).
    You need to follow up these steps:
    Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
    1.Go herehttp://support.acer.com/us/en/default.aspx and download the latest BIOS for the netbook.
    2.Extract the files from the downloaded zipped BIOS file.
    3.In the Dos_Flash folder, rename the BIOS file from 3310.fd to ZG5IA32.FD, in all capital letters.
    4.Copy ZG5IA32.FD and Flashit.exe to the USB flash drive
    5.Ensure that the AC adapter is plugged in.
    6.Insert the USB flash drive into a USB port.
    7.Press and Hold down the Fn and the Esc keys together and press the power button.
    8.When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
    9.After the keys have been released the power light will start to blink.
    10.During the BIOS update process the display will be blank.
    11.Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
    If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
    Good Luck
    Sep 27, 2011 | Acer Aspire One A150-1006 Notebook
    I have a acerbic aspire one that won't load to the net or restore to factory settings
    Hi:
    Do the following exactly how it reads:
    1. Go here http://support.acer.com/us/en/product/default.aspx and download the latest (check the latest date) BIOS for the netbook.
    2. Extract the files from the downloaded zipped BIOS file.
    3. In the Dos_Flash folder, rename the BIOS file from 3310.fd to ZG5IA32.FD, in all capital letters.
    4. Copy ZG5IA32.FD and Flashit.exe to the USB flash drive
    5. Ensure that the AC adapter is plugged in.
    6. Insert the USB flash drive into a USB port.
    7. Press and Hold down the Fn and the Esc keys together and press the power button.
    8. When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
    9. After the keys have been released the power light will start to blink.
    10. During the BIOS update process the display will be blank.
    11. Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
    Sep 10, 2011 | Acer Aspire One PC Notebook
    Aspire 5517 will not power up no lights, fans, nothing. Power supply checks OK
    Hi:
    1. Go here http://support.acer.com/us/en/default.aspx and download the latest BIOS for the netbook.
    Good Luck
    Sep 02, 2011 | Acer Aspire 5500 5570-2609 Laptop
    My acer aspire one 532h-2db blank screen but the power is on. please help me! thanks.
    Thank you for contacting Fixya. This is Anil.
    I understand that the Netbook starts but there is not display on the screen.
    It may happen due BIOS failure on the computer. Try updateing the BIOS. Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
    Go http://gd.panam.acer.com/home/ and download the latest BIOS for the netbook.
    In the Dos folder, Copy Flash.Bat; Flashit.exe; Nav50.fd to the USB flash drive
    I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
    Thank you. Have Great Day.
    Regards,
    Anil.B.R
    Jul 30, 2010 | Acer Aspire One PC Notebook
    I turn my Acer on and nothing happens. The light
    Try this it worked for me
    1. Go here and download the latest BIOS for the netbook.
    Note: These instructions are only for the Acer Aspire One AOA-110 and the AOA-150 netbook series and should not be performed on any other model Acer Aspire One.
    Mar 27, 2010 | Acer Aspire One PC Notebook
    With power but no display
    try pressing FN and F6 ....if not look very closly at screen with a bit of light on it and see if u can see a faint picture if so the back light has more than likely gone
    Mar 10, 2010 | Acer Aspire 4520-5582 Notebook
    Toshiba Satellite M115-S3094 Notebook Logo
    566 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
