Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
Compressor not working in upright Freezer AEG A75238GA1
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
Why is the temperature fluctuating.
Service engeener always checks the average temperature inside freezer or refrigerator compartment. When you turn on freezer, the compressor starts to circulate gas through the system and the temperature in the freezer is decreasing (go to minus). When inside of the freezer reaches the set temperature the compressor is switched off and temperature will increasing. What will be the difference of inside temperature depends on the type of refrigerator and type of thermostat or sensor and moves to max. 8-9 degrees. With the advent of new "No Frost" refrigerator, this difference was reduced to only a few degrees Celsius, thanks to the fan inside the refrigerator and NTC sensor.
So 29 + 14 = 43; 43/2 = 21.5 which means that your average temperature of -21.5 which is not too much deviation from the set temperature of -18 and I think that is ok.
Dado
Jun 13, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Orange light is on instead of green light on freezer what does this mean
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW: the upright freezer was on its back for about 8 ho...
It is usually reccomended to let it stand in it's normal position for 24 hours prior to running to allow any oil to run back to the compressor. Unit should work.
May 18, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
Left my upright freezer open a crack and now the
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
May 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Our Upright freezer is broken. You can hear it trying to kick on and then it doesn't. What is most likely wrong with this and is it worth repairing?
It could be a bad compressor start relay or a bad compressor. Replace the start relay,relatively inexpensive. If it still does not work the compressor is bad.
Oct 01, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Blows fusebox trip - all the time
good place to start is the starting device for the compressor.slip the cover off the compressor electrics on lhs of compressor usually and you may find the relay burnt out.tyhis is the mostly area but if elsewhere, look at the defrost element and check wiring loom
Apr 12, 2007 | AEG 7.59 cu. ft. / 215 liter Upright...
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
121 people viewed this question
Top AEG Freezers Experts
Gil Shultz
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
Are you an AEG Freezer Expert? Answer questions, earn points and help others
