On my Advent 4211 laptop, the computer isn't connecting to the wireless internet. I've tried everything, taking cables out then putting them back in, checking the settings etc. and still doesn't work. What should i do
You need to undate the wifi driver, there is also a bios update that needs doing....
Posted on Nov 08, 2008
Advent 4211 screen to base connection problem
Video Cable
The Video Cable connects to the motherboard.
It then runs along under the Left Hinge, and connects to the back of LCD screen.
{LED backlighting. Does not use a screen Inverter]
Due to just normal opening, and closing of the laptop; the Video Cable may be pinched.
This can cause the connection of the Video Cable TO motherboard, to be loose; and/or LCD screen.
Solution is to partially disassemble the laptop, and PHYSICALLY make sure the connection at motherboard is tight.
Visual inspection will NOT do.
Connection at back of LCD screen needs to be Physically checked also. (Try to plug in tighter)
Also visually inspect the sheath of the Video Cable, for apparent signs of damage.
Any signs of damage to the sheath, may mean damage to the tiny wires inside the Video Cable.
(Stretched/Broken)
Also due to the age of the laptop, suspect cracking of the insulation, of the wires inside the Video Cable.
If you have a multimeter, set it to OHM's (1K), and check continuity of every wire in the Video Cable.
Or take it to a small computer store, and have the resident tech check it.
The Advent 4211 is just a rebadged MSI Wind U100, according to my findings,
Disassembly guide,
http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
That's the problem, the Video Cable,
http://microdream.co.uk/advent-4211-c-lcd-screen-cable-k19-3030019-h58.html
[ In the photo, the large connector at bottom plugs into the LCD screen.
The smaller connector at the upper right plugs into the motherboard.
The separate black wire you see with the eyelet on it, is a Ground wire ]
For additional questions please post in a Comment
Regards,
joecoolvette
Dec 14, 2012 | Advent 4211c Notebook
Cannot get my wifi to work onmy advent 4211-b
Hi! Try to use the function key: FN+F11 to enable the wireless adapter. Check device manager if driver is properly installed.If yes, try to update the driver:right click on the realtek wireless LAN in device manager and then choose properties and then click update, choose automatically look for update from internet.If this doesnt work try to uninstall and reinstall the driver (make sure you restart the system after reinstalling the driver). If you have AVG as your anti virus sw try to disable it or uninstall it and then check if it will work.hope this will help...
May 29, 2010 | Advent Netbook
Computer will not start.
Well it seems that there may have been wither a compatibility problem or a .dll file has been erased. I suggest removing the recently added device, or any new hardware added see if that changes anything or you may have to reinstall Windows.
Feb 07, 2010 | Advent 4211c Notebook
Have an advent..use 3 dongle to connect to internet...in an area where there is no signal..this house has a router for wireless but i cannot get on..help..
Try to power cycle the modem as well as the router , disconnect all the filter and then turn off the modem and turn it back on make sure all lights are in green then try to connect internet cable first check if you have internet connection using cable then try to set-up your wireless connection again .
ERNZ
Feb 04, 2010 | Advent 4211c Notebook
Need advent 4211 keyboard
Checkout www.partmaster.co.uk
This is the spares departments for DSG who advent computers are manufactured for. Hope this helps :o)
Aug 31, 2009 | Advent 4211c Notebook
My Advent 4211 netbook connects wirelessly to the Internet through my Desktop and a Belkin router. How do I allow the netbook to see the files in the desktop?
if you ran your network wizard to get the internet access shared then you should be able to share your files too.
and folders the same way ,
go to my network device,
veiw network computers,
if you can see the computers desk top then
go to Shared folders and try to see if your folders have been shared open something.
If you can see the desktop and not open the shared folders then run the network wizard again,shutdown and restart,to save your settings,
to share files between both machines you will need to drag the file into my shared folders or rightclick on the file your sharing and click on sharing,follow the prompts to share and that should fix your problem.
Please rate me thanks MISTERDJ
Aug 16, 2009 | Advent 4211c Notebook
Advent 4211 Bluetooth Wifi problem
HP very recently has had problems with the actual wireless hardware. I found out when troubleshooting a friends HP laptop. Check for information on HP site to see if there is a recall.
Jun 18, 2009 | Computers & Internet
How do I connect to web?
As far am I'm aware the Advent 4211 netbook is not able to connect to the Internet 'on it's own' as such. Unfortunately the word 'netbook' has been advertised with this product in many PC World stores giving the wrong impression.
The best and easiest way would be to look into mobile broadband solutions.
Of course, it wouldn't do any harm to try out your Vodafone USB on their laptop to make sure it works well enough! :)
Mar 19, 2009 | Advent 4211c Notebook
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
