Lg lcd tv has no pitcher and is flashing a code
3 Suggested Answers
  • 109 Answers
SOURCE: tv lg blank screen
check oscilator crystal on main board, need scope to do that is a 50 mhz. hope this helps
Posted on Mar 28, 2008
freetek
  • 5568 Answers
SOURCE: 42" lg lcd tv pitcher flickers then gos black
Since the audio is still working, the main power supply probably
wasn't at fault and you may be looking at more research and possibly
more expense.
The problem is very likely on the largest board or with a failing
circuit that is part of the display.
You may be able to isolate it by using 'freeze spray' which you can
buy anywhere electronic parts are sold.
I suggest more than one can of it; ~ $7-8/can.
You will need to have the guts exposed and the set turned on.
Look around the edge of the display itself for chips (ICs) and give
any you see one brief shot of the spray, wait for ~1 minute for it to
'soak' and then move on to the next one.
If the video comes back, even if only briefly, repeat the cool-down
until you are confident to have found the right one.
If you can isolate it, you still have a problem.
If the sick IC appears to be 'glued' (with solder) onto instead of
through the board, you may not be able to replace it successfully.
If you can see that it has pins going through the board, these can be
replaced by anyone with a professional soldering tool and a steady
hand.
Remember, the problem can be on a board that is only connected to the
display panel but if on the panel itself, you may not be able to buy a
replacement for less money than a new set would cost.
Posted on Nov 10, 2011
What is the code for a LG 47LF6 LCD TV
LG codes are:0002,0606,0502,0102,0324,0435,0802,0307,0609&0217
press code search until the red light stays on then release-press the tv button-enter each code (four digits)-when you get the right one the light goes out, for an invalid code the light flashes-press channel up/down and you're on your way
Feb 02, 2012 | Televison & Video
more expense.
hand.
Nov 09, 2011 | LG 42LC2D 42 in. LCD HDTV
Tv pitcher went very dim standby light flashing red
the flashing light is an error code. How many times is it flashing?
Aug 31, 2011 | Sony KP-51WS20 Rear Projection Television
I cant get sky to work on my LG plasma tv
Hello
Codes to check for LG with Sky are;
065 244 405 318 037 398 191 459 245 389 080 275
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions
Mar 12, 2011 | LG 32LH30 32 in. LCD HDTV
No Code exists
Try this one
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Aug 16, 2009 | LG 32LH30 32 in. LCD HDTV
I have an LG 42lg30 and the user manual does not show you how to program other divices remote codes so the LG remote controls my cable box and dvd player. Does anyone know how this remote works?
go and buy a universal learning remote and you will be able to program all your devices on the remote, works very nice. as far as the lg remote, dont think there is a way where u can program your cable and dvd onto the remote and I have lots of experiences with LG
Mar 26, 2009 | LG 42LG30 42 in. LCD HDTV
Lg 26cl3000
TV
TV
0056
cheers
Little Dish Fitter
Dec 26, 2008 | LG 26LG30 26 in. LCD TV
No pitcher
The power supply is not providing enough voltage to the back inverter board due to leaky or dry capacitors in the power supply.
The power supply will need to be replace or repair to restore the LCD functionality.
Sep 17, 2008 | Astar LTV-3001 Television
Tv lg blank screen
Mar 01, 2008 | LG 42PC3D 42 in. Plasma Television
LG 42LC2S - Remote control code
After many months trying to find the BT Vision code for my LG 32LC2D, i have just had success with 005 remembering to enter an additional zero after the remote has flashed three times, so you enter 0005.
Hope it works, good luck!
Dec 24, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
