Question about Kenmore 500 6952 Dryer
When dryer first starts, it makes a strange noise then goes away after a couple minutes. Should I replace the belt?
    Sergeant:
    Champion:
  • 245 Answers
No. It might be your bearings. Kenmores are fun to work on for a novice mechanic. You're gonna need vice grips and sockets for this job.
Posted on Feb 15, 2012
  • 50 Answers
SOURCE: makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Posted on Jan 30, 2009
  • 212 Answers
SOURCE: gas dryer heats for couple minutes then goes cold
sounds like gas valve is not opening. your ignitor has to pull 3.2 to 3.6 amps to open gas valve. check amps
Posted on Jun 22, 2009
  • 3741 Answers
SOURCE: makes a strange noise, as if something is rubbing
Most noise complaints from this style dryer comes from the idler pulley and two drum support wheels. The idler pulley just clips into the bottom of the dryer and keeps tension on the drum belt. The drum rollers have clips that must be removed from the shafts before trying to replace them. If one wheel is worn out, replace them both = less problems later on. See "how to take apart" to access the rollers, once the belt is disconnected from the idler pulley and motor pulley, lift out the drum. The roller on the left has a bracket and 2 clips to remove before the roller can be replaced. The right roller has just 1 clip that must be removed to replace the roller. Use a cloth or fine sand cloth to clean up the shafts, use a light oil before installing the new rollers. DO NOT use a heavy grease as this will attract dust and become very dirty and gum up the rollers. Check the belt will you are there and clean out any dust from motor and from the drum base. See how to take apart information. Anew picture of the roller, shaft and clips... you can get the required board and components at ----- www.partselect.com -------- or from ------ www.repairclinic.com ----
if you are not familiar with doing this you can get it done by local appliance repair technician familiar with this model.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 24, 2009
Testimonial: "Thanks for your help"
sonicboomele
  • 1557 Answers
SOURCE: I replaced the motor in my Kenmore gas dryer when
sounds like the motor is over heating i would try lessining the tension on the belt
Posted on Apr 20, 2010
heatman101
  • 43501 Answers
SOURCE: The dryer is making a thump/thud noise as the drum
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
When we start the dryer it's stsrt making loud noise matal to metal then it goes away for few minutes and comes back
Hi bojanhadziki...
You could have a couple of problems..
1...The door seal may need replacing, making metal to metal contact
2...The drum rollers may need lubrication or replacement
3...The back bearing may need replacement or lubrication.
Please take time to rate me
Sep 26, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer was making strange noise when drying clothes. stopped the dryer and removed the clothes. dryer would not start again, never had any problems before.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 02, 2011 | Dryers
My Roper dryer was making a strange rattling noise for a couple months. Then it started not drying my clothes completely. Not it just won't start at all. Its only 3 years old...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 25, 2010 | Roper Dryers
My car is making this squeaking noise wen i start it. then wen i drive it for 20 min it gose away? people have told me that its my pulley or my elt idk which one it is??????
With the car running, spray WD-40 or equivilqant , one belt at a time when the noise goes away after spraying THAT belt is the culprit.....do first thing when starting car fo first time.
Apr 30, 2010 | 1995 Buick Park Avenue
Dryer makes squeaking, rattling noise whe starting. Goes away after a couple of minutes.
sounds like your bogie wheels may be starting to ware out they are bottom left and right drum inside front panel if worn they take 10 mins to replace
Dec 18, 2009 | LG DLE2532W Electric Dryer
I have a 2003 Hyundai Santa Fe V6 3.5L with automatic transmission. 48K miles. When I start the car after sitting over night, I hear this whirring/whining noise from the engine compartment. I goes away...
your whining noise might be comming from dry belts in order to pinpoint your problem have a jug of water ready before startup open the bonnet then startup if the noise appears pour water over the belts if noise goes away replace v belts
Jul 13, 2009 | 2003 Hyundai Santa Fe
Dryer
Your machine uses a belt tensioner of the type that the belt 'glides' on, creating a squeak noise that #1 will get worse and #2 is wearing out the belt. Replace the old tensioner with the one pictured here. The squeak will go away and the belt will last longer.
If you need further assistance, or instruction on disassembly, let me know
Regards,
reg501
Jun 27, 2008 | Roper RGX4634KQ Gas Dryer
Kenmore 500 6952 Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
