Question about Epic 425 Mx Treadmill EPTL88105 !
Turns on and then shuts off before it will start even after hitting reset
We checked the wall connection and that seems ok
    Top Expert:
  • Epic Master
  • 12,223 Answers
Dear Sir:
This problem is frequently.
1) Check the breaker from your home and reset.
2)Inspect the wires from your outlet in the wall and tight it.
3)Do not use any extension cord!
4)Examine the power cord and see if some wires is loose and tight it.
5)Test the ground from your outlet wall, and fix it.
6)Reset the c. breaker internal from the treadmill.
7) Inspect any wires loose and tight it.
8)Lubricates the treadmill between deck vs walk belt, this can cause to shut down the treadmill, since the complex electronic is designed for to protect the electronic components.
9) Lubricate the treadmill in according with your manual instructions.
10) The ball bearing from motor can be faulty+ball bearing from roller deck.
11) The main motor board can be faulty. ( this is last step)
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Posted on Feb 15, 2012
KEMS308SSS KitchenAid Wall oven - Error F3E0 - Sensor seems OK
The RTD could be in spec at room temperature but failing under load
May 21, 2013 | KitchenAid Architect® KEMS308SSS Stainless...
Shuts off when eject button hit.
does it open when you when you connect it direct to the wall scoket.
Jun 04, 2008 | Quasar VM-L153 VHS-C Camcorder
Tip
Cannot access internet!!!!!
Using Windows Operating Systems:
Windows XP:
1.Powercycle equipment (Unplug power wait 15 seconds then plug back in)
2.Go to Start/Run/Type ncpa.cpl then hit ok.
3.Double Click Wireless Connection (Router Connection) Hit Properties.
4.Click on tcp/ip then hit Properties
5.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
6.Restart Computer, If still unable to access internet check you Firewall:
Start/Control Panel/Windows Firewall/Change Windows Firewall Settings/Turn Off not recommended.
7.Last Go to Start/Run/CMD/Hit ok
A.Type netsh int ip reset reset.log Press Enter after every Command
B.Type netsh int ip delete arpcache
C.Type netsh winsock reset
D.Type ipconfig /flushdns
8.Restart Computer
9.If still having issues check for viruses or malware in your computer.
10..Refer to your manufacture.
Windows Vista/7:
2.Go to Start/Search Bar/Type ncpa.cpl then hit Enter.
3.Right Click on your connection usually (Wireless) then click Properties.
4.Uncheck Internet Protocol Version 6 IPV6
5.Click on Internet Protocol Version 4 IPV4 Then hit Properties (Do not uncheck IPV4)
6.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
7.Restart Computer, If still unable to access internet check you Firewall:
A.Start/Control Panel/Security/Allow Program Through Windows Firewall/General Tab/Turn Off.
8.7.Last Go to Start/All Programs/Accessories/Right Click on Command Prompt then hit Run as administrator and hit continue.
10.Refer to your manufacture.
on Jan 11, 2011 | Computers & Internet
Wont't start
check battery conection to see if terrms are clean and good connection to batt and starter
Apr 12, 2012 | 1994 Nissan Quest
Can't connect to the internet with router
1.Powercycle equipment ( Unplug power wait 15 seconds then plug back in. 2.Make sure connections are tight in to the router and to the modem. 3.Check you network settings Windows XP: Start/Run/Type ncpa.cpl and hit ok. Check and make sure that your connection doesnt say Connected Firewalled if it does to the left hand side you will see change windows firewall settings turn to off.If it doesnt say that double click the connection hit properties click on internet protocol and hit properties again,ensure that obtain ipaddress automatically is checked as well as obtain dns server automatically If not check them both and restart your computer. Windows Vista/7 Start/Search bar type ncpa.cpl right click on your connection and hit properties uncheck ipv6 and click on ipv4 and hit properties. After Ensure obtain ip address automatically is checked as well as Obtain DNS server automatically is checked restart computer. 4.Use command prompt: WIndows XP: Start/Run/Type cmd and hit ok Windows Vista/7 Start/All Programs/Accessories/Right Click Command Prompt and hit run as administrator. 5.Type in Command Prompt the Following Commands Each line is a seperate line is a new command simply press enter after each. netsh int ip reset reset.log netsh int ip delete arpcache netsh winsock reset ipconfig /flushdns 6.Restart Computer Final: If you still have issues connecting refer to router manufacture.
Jan 12, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
It showing that it connected but web page can open
1.Powercycle your equipment ( Unplug then plug back in) this means your Modem and your Router.
2.Open Network Connections. Xp:Start/Run/Type ncpa.cpl then hit ok
Vista/7:Start/Search bar type ncpa.cpl then hit enter.
3.Right click on the connection your using and hit properties, Uncheck Internet Protocol Version 6
Click on Internet Protocol Version 4 and hit properties.
4.Ensure obtain ip address automatically and obtain DNS server automatically is checked if not check both boxes.
5.Disable all firewalls, Xp:Start/Control Panel/Switch to classic view/Windows Firewall/Turn Off
Vista/7 Start/Control Panel/Security/Change Windows firewall settings
6.Disable Antivirus Software.
7.Renew Ipaddress XP:Start/Run/Type cmd hit ok
Vista/7: Start/All Programs/Accessories/Right Click on Command Prompt click run as administrator. Hit continue
8.In Command Prompt type the following: netsh int ip reset reset.log Hit Enter
netsh int ip delete arpcache Hit Enter
netsh winsock reset Hit Enter
ipconfig /flushdns Hit Enter
9.Restart Computer
10.If still unable to connect run antivirus and check for errors refer to your ISP Internet Service Provider
Dec 05, 2010 | D-Link DIR-600 Router
Can not get connected
Powercycle (unplug power) all your equipment, Modem/Router waite 15 seconds then plug back in. If you are having an issue with the ip address not valid you can try these steps
(win xp) Start/Run/Type ncpa.cpl hit ok, You will see wireless connection double click wireless connection this will bring you to the properties. ensure that the connection is assigned by DHCP also check to see if you have a valid ip address
Win Vista/7 Start/Search Bar/Type ncpa.cpl Right click on wireless connection and hit properties. Uncheck Internet protocol version 6 and click on Internet Protocol Version 4 and hit properties/Ensure that obtain ip address automatically is checked as well as obtain dns server automatically. hit ok close out.
Go to command prompt Win XP Start/Run/Type CMD hit ok
Win Vista or 7 Start/all programs/accessories/ right click on command prompt and hit run as administrator.
At command prompt type;
netsh int ip reset reset.log hit enter
netsh int ip delete arpcache hit enter
netsh winsock reset hit enter
ip config /flushdns hit enter and restart computer this will reset the ip address hope this helps good luck
Oct 01, 2010 | Computers & Internet
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
Electrical Dies when I start
You have to check the battery cables for corrosion and loose connections , from your description tht of when hitting the starter button you loose all connections thts a typical sympton of loose connection especially on the main wire.
Go through the complete wiring and connections of your bike and spray WD-40 to all connections it will help clean up.
Good luck.
Knight (Yamaha XJ750A 1981)
Apr 16, 2009 | 1995 Suzuki VS 800 Intruder
Ink system failure
This happened to me two days ago. We did a live chat with HP and they took us to a special menu in the machine. We had to erase the error and then reset. It is working perfectly now.
HOLD down * key and then # key and let both go at the same time.
Hit and release in sequence 1,2,3.
Using right arrow key go to configuration menu.
Hit OK.
Hardward Failure status.
Hit OK.
To clear press OK.
Hit OK.
Cleared.
Cancel back out to main menu.
Shut down with on button.
Unplug from machine then wall.
Wait 30 seconds.
Reverse process to turn back on.
It will cycle through its beeps and clicks.
Do a test print.
TADAHHHH!!!
Jun 11, 2008 | HP Photosmart C6180 All-In-One InkJet...
Epic 425 Mx Treadmill EPTL88105 ! Logo
148 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
