Problems with Samsung LE37M87D TV . When I connect my SKY HD Thomson box with this Samsung TV I get a few lines on the screen which makes it unwatchabable., Thanks
harry0000010
  • 40 Answers
SOURCE: unable to get a sky
swap out the sky box and see if that helps...or take your box to your friends house and see if it works there..........
Posted on Feb 03, 2008
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
  • 4234 Answers
SOURCE: Samsung tv won't work with
What do you mean by not working. What happens? What is the connection from the box to the TV?
Dan
Posted on May 29, 2008
  • 905 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
  • 1030 Answers
SOURCE: Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Posted on Oct 31, 2008
I HAVE AN OLD THOMSON SKY BOX(NON HD) CONNECTED TO A SONY BRAVIA 32BX320. THERE IS A POOR RECEPTION ON SKY CHANNELS PARTICULARLY NOTICEABLE ON SKY SPORTS FOOTBALL WHERE IMAGES ARE "DRAGGING", "DELAYED
First step...clean out the "old" guy with clean, dry, compressed air to get dust off the capacitors and resistors. The frequencies that the "box" selects are regulated by those components. If this doesn't work you should realize that the electrical values of those components change as they age...and like grandma, can't do the tricks they used to.
Jan 12, 2013 | Televison & Video
HD not working.
Have you connected it Via HDMI? if the screen is still connected via Scart then that is the problem.
May 03, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
LE40R74BDX HDMI input stopped working
I work for sky as an engineer (not a subby)
HDCP is the encryption that is sent down when a program is transmitted. I have had this several times over the years and have found out that you need go to the manufactors web site or call them to update your telly this will sort out this problem.
I would do this sooner then later... reason I am telly you this is sky have take the Component inputs off all the sky boxes now.... The box you have is a THOMSON (have a look.... make you smile)lol this was due to people connecting there sky HD box to there pc via Component and using programs like Copy+ and extract + to copy the content.
If your box breaks down. then you are snookered if you telly is not going to accept the skyHD through a HDMI connection.
Hope this helps
Cheers
Little Dish Fitter
Mar 04, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Struggling with Sky remote codes for new Samsung TV LE32A457
0060, 065, 584, 037, 245, 476, 398, 516, 292, 318,037
these are samsung codes for sky remote
good luck
Dec 29, 2008 | Televison & Video
Sony kdl40v200
I work for sky as an Engineer (not a subby)
HDCP is the encryption sent down when a program is transmitted. Over the years I have had several jobs where this is the case.
What you can do to fix the problem is Download update for your sony bravia telly this will fix the problem. There is another solution, if you get another engineer out ask him to put a different manufacturers box in..... Sky HD is made by Thomson, samsung, pace, Amstrad,
both solutions have worked for me when coming across theses faults whilest installing sky... The first one is going to be your best option... for example at the minute all I am getting when i go to pick my HD stock up is Amstrad. No other manufacturers so you may find it hard for the engineer to source you a different make.
If neither work. Force a download to your HD box (they have been updating the software recently so this may also work for you.)
Take the power out the back of the HD box. hold down the Standby button then reinsert the power. hold Standby button in until all light are lit on the front of the box... Then wait 10 minutes (better off making yourself a cuppa) give that one a try.
Hope ive been of some help to you
Little Dish Fitter
Sep 17, 2008 | Sony BRAVIA KDL-40V2000 40 in. LCD...
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me (dodzio24@o2.pl) and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
May 19, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
