My dvd burner is failing to burn dvds - Computers & Internet
  • 94 Answers
Hi ahoward
its sounds to me like the laser source is weakening on the write action only thing you can do is replace with new or soon you will find read action will start failing too, you;ll get a good deal at www.ebuyer.com
Posted on Oct 25, 2008
Not Reading DVDs and Dual Layers
Enable DMA mode, and choose reducing burning speed. Is a Low Quality DVD-Drive, I prefer ASUS DVD-Drive. Reads all, and Burning without fails,
Jul 12, 2010 | LG Computers & Internet
My computer wont recognise my dvd burner but it will read and play dvds just wont burn them and when i try a new dvd burning tool it cant fint my burner
Is your DVD drive a Combo DVD ROM and CD Read/writer? If so it cannot burn DVD only reads DVDs and read and burn CDs.
If the program cannot find a DVD burner then either the burning software cannot support that model DVD burner ot the DVD burner is faulty.
To test the DVD burner, remove it and install it into another computer to test the burner to see if is faulty.
Jun 24, 2010 | Philips CDD 4801 CD-RW Burner
LG DVD writer GH22NS 50 is not writing in empty DVD but writes in DVD-RW
Hi as your burner is OK for your dvd-rw but wont burn dvds, try a different brand of dvds.Quite often a drive will not burn one brand but will burn another brand. Hope this helps.
Regards Bill
May 17, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
Writes to 8x dvds but not 16x dvds. Why?
It could be lower quality media that the drive does not like for 16x writing. I would try a higher quality blank DVD. It could also be the software you are using. I recommend imgburn from http://www.imgburn.com/ which is a great little free app. This program is a very no nonsense burning app without the bloat of most other programs.
If you buy a single or 5 pack of high end media and use imgburn yet it still will not burn at 16x speeds I would contact Mad Dog as you may have a bad drive.
Aug 22, 2009 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Drive Can't Burn DVDs
If it is a combo drive then you cannot burn DVD's with it.
A combo drive can burn CD's and play DVD's
If it is a burner, then install Nero and burn DVD's with that. But as above, if it says it's a COMBO drive, then it can't.
Apr 21, 2008 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Unable to burn using a LG GSA H58N DVD burner
With the built in drivers for windows XP it can identify and use DVD-RW facilities of DVD burner. However depending on your bios your machine can fail to burn DVDs if your bios can not recognise that output.
While loading the CD that comes with the DVD-RW did you get an error message if yes then it means you BIOS is failing to recognise your DVD-RW as an output method try to update the BIOS. But before you do that if you can try adding the drive on a modern (after 2002) machine with xp and see if it can burn DVDs there without adding any drivers.
if it fails on that other machine then you can be sure its not your BIOS but a problem with drive (which I suspect most actually). But if it works then then you need to update your machine bios.
Mar 25, 2008 | Computers & Internet
Problems Burning DVD's
Ya didn't say what Operating System?... Ensure ya have all the correct "Settings" in the Burn software. Sometimes the actual type of DVD media can be an issue... some dvd's just don't "Like" some DVD's I have found... try the best brand ya can afford... if still no go.. try Alcohol 120% & CopyToDVD both use their "Own" "Drivers" and I have had great success.. where others have failed..
Aug 07, 2007 | Optorite DD1603 DVD±RW Dual Layer...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
