My Zenith DVB312 player plays sound but now there is no video. I have tried it on two different TV's and with different AV cables and different DVD discs.
-   I've got the same problem on a Samsung DVD-HD950. Connected to TV via HDMI the TV gets sound but no picture. Taking the DVD out, but leaving the device on, I held the fast froward button the machine (not remote) for about five seconds. This is supposed to reset the video to the factory default. After that I had video back.-   mr wilf
Jan 06, 2008
-   I have the same problem with the VCR part of my combo player. I can see/hear DVD's just fine but I can't see videos. I can hear the sound but can't see the picture. I have checked and rechecked the cable connections and they all seem to be fine. When we first plugged it all in it worked fine. But, the next time we tried it, we only got sound, no picture. Could there be some button we've switched that should not have been switched? Please help!!!-   Pat C
If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service.
the unit comes on for a minute before the error appears,and as far as i can tell, the drive and the...
(More)
the unit comes on for a minute before the error appears,and as far as i can tell, the drive and the laser both work
The power on my DVB312 will not turn off and the disc tray will not open with remote or when button...
(More)
The power on my DVB312 will not turn off and the disc tray will not open with remote or when button on front of player is pushed. The DVD player appears to be frozen or locked up. I've unplugged the DVD player for a few minutes and "HELLO" has disappeared from the DVD player's message screen, but the DVD player still will not accept commands or turn off.
(More)
(More)
