You can go to Toyota.com, click the owners link, register you vehicle, and have full access to the online PDF version of your owners manual.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: 2005 scion xb Stereo problem
If the Stereo Got wet, The first thing that will stop is the Internal Amplifier. On these Pioneer Stereo's the Only thing that You can do is Replace the Head Unit. Please Rate My Response! Thanks!
SOURCE: Replace front speakers
its actually pretty easy. just remove the screws on the door panel. dont forget the one in the handle at the bottom. then remove the little triangle cover behind the mirror on the door. lightly pull from the bottom and the door panels pop clips will slowly come undone....once the door panel swings outwards pretty easily just lift up on the panel and it will come off....once its undone you can either remove the harness for the window switches and lock or just let the panel sit to the side still attached. either way works its just preference. then you just remove the speaker and replace with any 6.5inch you would like... reinstallation is the same..
SOURCE: I can't find the fuse box on my 2009 Scion XB
Fuse box is located in the engine compartment. Over the drivers side wheel well. just lift the large rectangular cover.
Hope this helps
SOURCE: need help to remove 2005 Scion xB water pump
1st ...that should be covered under 6 year 50k power train warranty from the dealer.
But if your over....you need to unbolt the right side motor mount (on the water pump side) and lift the engine some with a floor jack to get clearance,
SOURCE: Remove 08 Scion XB Navigation
The trim around the stereo and center vents pulls straight out. It is held in by plastic reusable clips. No tools needed.
