Question about Microsoft Xbox 360 Elite Console
Xbox elite ip adress failure
I can take my regular xbox 360 ethernet out, plug it into the elite and the ip adress will fail everytime. i can plug it into my regular 360 and it will connect everytime, dont even have to restart anything. i dont understand this.
From the question above I think you are saying that when you unplug your Ethernet cable from your Internet connection out of your E-BOX and try to use it in your laptop, it doesn't work. If this is correct, then it's probably that your ISP only allows for 1x active address to be used at any one time. To overcome the problem you'll need to also power recycle your Internet modem to clear out the MAC address of the X-BOX once you've unplugged it and before you make the laptop connection. You would have to do this each time you wanted to swap between the devices.
Alternatively, get yourself a Router to sit in between the Modem and end devices and then have an additional permanent cable / 2nd physical port to use.
Posted on Oct 25, 2008
Im trying to set up xbox live wih at&t with a ethernet cord and it says the IP adress failed but i dont know how to fix it. i have a xbox arcade
your xbox is having trouble finding and connecting with the internet. try rebooting the system or upgrade your internet connection
Sep 24, 2009 | Microsoft Xbox 360 Arcade
Ip adress failed
u should try ringing ur internet server and u dont connect it to ur laptop u connect it to ur modem and router and btw for some reason xbox live doesnt work for everyone it weird but no one knows why
May 09, 2009 | Microsoft Xbox 360 Elite Console
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Cannot connect belkin wireless adapter to my xbox 360 thru my pc
every computer has an ip adress you might have to go to your internet setting and find some thing that says some thing like... internet adress hook up hopefully you keep files on your computer becuase with out your ip adress you might not be able to hook up its sorta like a combination hope it helpes:)
Mar 02, 2009 | Belkin Video Game Consoles & Games
Ip address failed
In order to connect your XBOX 360 to your laptop (if the laptop is connected via dial-up), you'll need a cross-over ethernet cable. It's a special type of ethernet cable, which is typically the same price as a regular ethernet cable, but it allows two devices (in your case) to communicate with each other. Then, you'll need to configure your laptop to allow incoming connections via your Control Panel -> Internet Connections preferences.
Hope this help!
Robert W.
Jan 08, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont take ip anymore
go to your router. find what your ip pool is. choose an ip that is in that pool. set up your xbox's internet manually. you need the gateway, DNS, and everything (you can find this on your router online) this will give your xbox a static IP and might fix your problem
Aug 10, 2008 | Microsoft Xbox 360 Elite Console
Ip adress
are you connected tou your hub or pc?
Aug 02, 2008 | Microsoft Xbox 360 Elite Console
Ip adress
this is not a fault with the xbox 360 rather it is a problem you have with your internet connection or router. you'll have to check or possibly renew dhcp (the protocol that issues ip addresses on your router if you use one) or contact your isp about it.
Feb 10, 2008 | Microsoft Xbox 360 Console
Xbox 360 elite live
It may have trouble recieving the ip addrees from the router, but not sure what switch you are using if you have a router you should connect directly unless its a wireless switch.
Aug 29, 2007 | Microsoft Xbox 360 Elite Console
Microsoft Xbox 360 Elite Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
