Question about Flotec Garden
Flotec fpoc 1500 utility pump 1/2 hp repair manual
How can I get the impeller from the shaft? By turning or by prying it?
4 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: I need a power cord for my 1500 gph 1/6 HP Flotec submersible pum
Get ready for sticker shock:
http://www.abtecparts.com/simer_cords.htm
Simer and Flotec parts are interchangable.
Posted on Feb 24, 2009
  • 990 Answers
SOURCE: need impeller for a flotec 5acmp drill pump
Try to match it to sta-rite PLBC
Posted on Aug 24, 2009
  • 990 Answers
SOURCE: How do you remove the motor from a Flotec FPS5172, 1-1/2 HP.
The impeller screws on the motor shaft. First replace the through bolts in the motor. These are the long bolts, they will just cause headachs. On the back of the motor their will be a place to hold the shaft from turning, If you hold the shaft the impeller just unscrews. If you look in the center of the impeller it may have a set screw holding it to the shaft. If you have one of these it will be a left hand screw. Then you will need to break the impeller free as the brass that holds the impeller on will stick to the stainless steel of the shaft. Don't let how tight this is fool you when you put this back together it just goes on hand tight. Good luck
Posted on Nov 28, 2009
Have new impeller but pump will not pump
Did you find the piece of impeller or pieces of impeller broken off. May be clogging system up. Need to back flush system to make sure clear.
May 31, 2012 | Flotec 1/12 Hp Multi-purpose Utility Pump...
Need a owners manual for flotec pump At251001-01
All you have to do is remove the back cover loosen up the gray contact and hold the shaft with a 7/16 wrench. Scroll down on this website and follow pics. Good luck.
http://www.troublefreepool.com/is-this-impeller-broken-t22383-20.html
Tony
May 23, 2012 | Flotec Pool & Spa
I have 2 flotec cyclone pumps. Both need impellers. Where can I get them? I don't need a whole repair kit. Just the impellers.
I believe you can find it at this website.
http://www.pumpagents.com/JabscoPumps/Jabsco-Impeller-Guide.html
Good luck
RJ
Nov 10, 2011 | Flotec 1/2hp Cyclone Pump
How do you remove the impeller from the motor shaft?
Thank you for posting your question here on Fixya.com.
Lock the shaft using a wrench at the end where the electric leads connect. Then spin the impeller off counter-clockwise.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 13, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Pump quit....gets hot!
THAT IS A CHEAP PUMP. JUST BUY A NEW ONE, THEY ARE HARD TO GET SEALED BACK UP AND JUST TO FIND IT WORKED FOR A WEEK.. VEGETABLE OIL .. IT MUST BE NON TOXIC OIL !! .. VOTE
May 24, 2010 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Nov 23, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
My flotec 4/10hp waterfall/utility pump was working fine for about 1 hour, now it's only humming and not pumping any water... ?
Clogged, Impeller loose and not turning. Remove strainer from bottom of pump and check for clogg and see if the impeller is turning.
Sep 21, 2009 | Flotec 4/10 Hp 3000 Gph Waterfall Utility...
I need a power cord for my 1500 gph 1/6 HP Flotec submersible pump. where can I get one? Cat # u2 Serial # 50833
Feb 17, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Garden Logo
81 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
