Display Issue, Hisense 42" LCD
I have a vertical white line (band), approx 4" from right side. Very easy to see when background is dark. When watching in HD or wide screen it is very noticable. Image in side that band is darker. In other aspects the band is outside the "box" and line (band) cannot be seen. Any Ideas? Cannot get Hisense Tech Support to return calls.
    Top Expert:
  • Televison & ... Master
  • 75,471 Answers
Hello
Do a factory default reset to this set. You can get details about how to do this, from its user manual. If it does not help you, the t'Con bard [Timing Control Board] may need replacement.
The board sill look like this.
http://www.dataentryjobs.us/67948.htmlDisplay Issue, Hisense 42
Posted on Feb 15, 2012
4 Suggested Answers
jojack2k5
  • 34 Answers
SOURCE: vertical bands on screen
bad x drive board on bottom of set where lines appear
Posted on Apr 29, 2009
  • 72 Answers
SOURCE: 42 in Panasonic Plasma TV - 4in wide vertical
take it apart and reseat connectors on bottom buffer boards if not may need to replace buffer boards on bottom of tv
Posted on Jun 07, 2009
SOURCE: I have a videocon 42
What you need is known as a "Z buffer" or "address buffer".
It is a board located UNDER the display.
Can't tell you the board number because you do not mention the TV model, but if you are up to replacing it yourself you better get to there anyway and see the model printed on the board itself.
There are usually two boards underneat in the 42'' models, sometimes three, but usually two.
You need to find the one located where the vertical line shows and replace it.
Replacement is not hard, but requires a bit more unscrewing because those boards are usually covered by metal shielding / heatsink, which usually has quite a few metal screws.
Other than that, though, it is not hard.
Posted on Mar 23, 2010
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Vertical white wide band - Shivering fonts
Unfortunately that sound like a defective LCD panel. You can verify this by plugging the system into an external monitor. As long as the shimmering band does not appear on external display then it is the LCD. If it is under warranty I would suggest taking it into Apple.
Aug 16, 2009 | Apple MacBook Air Mac Notebook
Background ghost like images
CHECK IT IN THE DIFFERENT ASPECT MODES. IF THE IMAGE STAYS IN THE SAME PLACE REGARDLESS OF ASPECT. THEN YOU HAVE A LCD PANEL PROBLEM. PANEL WILL HAVE TO BE REPLACED.
Feb 27, 2009 | Televison & Video
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Hisense[gva] modelPDP421 plasma
You most likely have image burn in on the display if it is not in a straight line. If it is in a straight line than it can be dead pixels. It is most likely the first issue I saw this same issue at work with an HP plasma TV.
May 10, 2008 | Hisense TA42P40M 42 in. Plasma Television
HISENSE TA42P-HDRA
I am from Tunisia & ibought a tv plasma HISENSE from CHINA 2 years ago;i have a vertical white line(10cm) in the midle of my plasma(Hisense 42"),after 10 mn the tv is on.What can i do?
Oct 31, 2007 | Hisense TA42P-HDRA Television
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
