Broken foot switch
SOURCE: How to change belt on Panasonic MC-E464 vacuum cleaner
Remove the bottom plate, the belt goes fron the brush rol to the motor shaft or pulley.
SOURCE: vacuum cleaner belt
Just take off the bottom plate covering the brush roll. The number of the belt is 38528040. Check the brush roll to make sure the ends turn freely, if not the replace it.
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution. I'm pretty sure you will find there are two filters. The first is a foam filter, and is located at the bottom of the bag compartment. It pulls out to the front, and is washable (of course it must be completely dry before re-use). The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door. The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response. Good luck!
SOURCE: The foot switch does not turn on the G4D Kirby vacuum cleaner.
Here's a link to a free guide! The switch is available at this site as well...there is a link in the guide to buy one.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
SOURCE: Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
