Question about Delta 10"Hybrid Tablesaw with 30"Unifence
I have a Delta 10" table saw #34-670 tripping the breaker.
I have replaced the 20 amp. breaker and am running #12 wire. I have also cleaned the brush holders and reset the brushes in the motor. It still continues to trip. Other than replacing the motor (#131334), does anyone have any other suggestions? If it is the motor, which part number do I need? Thank you. fishnguy@verizon.net
3 Suggested Answers
  • 132 Answers
SOURCE: burning electric tool brushes
there is suppose to be some flash coming from the brushes. If there is no flash then the tool will not work
Posted on Feb 02, 2009
  • 62 Answers
SOURCE: Motor not working on Delta table saw: I just got a
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Posted on Apr 18, 2009
Table saw keeps tripping breaker
May have a brush in the motor that's hanging up or worn may try
replacing the brushes
Feb 07, 2014 | Saws
I have a 10" Delta table saw. It was running rough
Check that the blade is not warped or binding. Don't use long extension cords. Check your home breakers. Also check if the table saw has a breaker. Don't force lumber into the blade too fast and don't jam the lumber between the guide and blade. Try a different outlet and check your wire for breaks. Good luck!
Oct 05, 2011 | Saws
Brand new saw trips 20 amp breaker every time I turn on the saw. It starts to turn and after about a second the breaker trips. Have tried different plugs on a different breaker. Still it will not start....
How long of an extension cord are you using? Is it at least a 14 gauge wire? It should be 12 gauge. If it 16 or a long 14 it will cause the problems that you mention.
If this is occuring when its plugged directly into the outlet then it is likely a problem with the saw. Before you take it back tho try another outlet on a a different circuit.
Jun 30, 2011 | Dewalt DW744XRS 10-inch Job Site Table Saw...
Table saw overheats triping braber. have cleaned contacts and tighten the conections on the side of the saw.
Usually a saw that size will have it's own breaker built in, is this the one that is tripping? Or is it the one on the wall? Either way, a dull blade will make the saw work harder, and heat up faster, Mine trips off now and then, always from a dull blade. It has a built in breaker in the switch. Are you running it with a cord? Make sure it is heavy enough, a small cord will steal amperage from the circuit turning a 20 amp breaker into a 15. Hope this helps.
May 28, 2011 | Hitachi C10FL 10" Stationary Table Saw...
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
Oct 20, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
14" Delta Bandsaw keeps tripping the internal motor breaker.
The first thing that I would check is the wiring to the saw. My guess is that the wire to the saw or the cord is not heavy enough.
As saw like that can pull a lot of amps. Probably 15 or more when working hard. What happens is that when the amp draw goes up and the cord is too light, the voltage drops which increases the amps. and starts a vicious cycle...
The one thing that finally gives is the internal overload in your motor.
Try running heavier wire or a heavier extension cord if you are using one.
#12 wire or a 12 wire cord would be minimum, if running over say 50 feet then you should be looking at #10 wire.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 29, 2009 | Delta Saws
My table saw stops after a minute or two i replaces the capacitor and still does the same the breaker pops out
This means it's drawing high amp. Could be just packed with saw dust, getting hot. The breaker is probably thermal. Clean it up good. If it still trips, check for name plate current on motor and test.
Jun 22, 2009 | Delta 36-716B 10" 1-3/4 HP 120/240V...
On/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Nov 02, 2008 | Saws
Delta 10"Hybrid Tablesaw with 30"Unifence Logo
96 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
