Holding the Cycle End Signal button for 3 seconds is the way to turn the control lock off and on with this model. If that is not unlocking the control like it should, the first thing you would want to try is unplugging it for 5 minutes to let the controls reset.
Unplug it overnight to fully dissipate power from the control board memory.
The easiest way to reset a Maytag washer is to disconnect the power to the washing machine for three minutes. Disconnecting the power allows the electrical charge to dissipate from the washing machine, which allows it to reset. If the reset fails, unplug the washer again, this time leaving it unplugged for ten minutes.
Dec 2, 2021
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
