Question about ASUS U36J SMB PC Notebook
Hard drive is full - ASUS U36J SMB PC Notebook
Funlux surveillance hard drive issue. 1 tb, is full, need formatting , it takes 5 minutes plus to format. Every 2 minutes it reboot, trying to record, won't finish formatting. Disconnected cameras,
You did not post the model of the unit. There is a port for external drive support and there is an internal drive depending on the model. You can try formatting on a computer if you would like or you can select OVERWRITE recording when the HDD is full
1. Access the [General Settings] and open the [Disk Drive Info] page. 2. Open the drop-down menu at the top next to the "Hard Disk Drive Full", select "Overwrite" and press save.
Jan 07, 2017 | Hard Computers & Internet
Toshiba hddr160E03X hard drive showing full capacity at 147GB
Manufacturers rate the capacity of their hard drives in an unformatted state. When you format a hard drive the actual capacity drops approx. 10% and in this case it leaves you with 147Gb capacity.
Feb 06, 2012 | Computers & Internet
Hard Drive is full
if the Hard Drive is full you need to remove some software or any large file from the computer to free up some space on the Hard Drive , may want to buy another hard drive or get an External hard Drive to help with the space problem .
Jan 27, 2011 | Dell Inspiron 530 (883685981020) PC...
I've got a Compaq Presario PC with a 40 G hard drive. The drive is at 99% full. How can I move some files to a new laptop I have with a 320 Gig hard drive? Joe C.
Any images, pictures, movies, or other personal files can be burned to a CD or DVD which can then be transferred to your new laptop.  Upon successful transfer, you may then safely delete the files from the full hard drive on your Presario.  Since your hard drive is so full, you may need to move files in small pieces since space is required to "burn" data to CD's or DVD's.  You can perform a "Disk Cleanup" which will delete files in Recycle Bin and Temporary Internet files.  To do this, Right-click on the Hard Drive, Click on Properties and click on the Disk Cleanup button.
Nov 09, 2009 | Office Equipment & Supplies
I have an Acer 5720 laptop with 80GB hard drive thats full.
To remove temp files and old compressed files run Disk Cleanup to free up disk space.
Click on My Computer then right click on the C drive and then Disk cleanup, if you have never done this before it will take a long time to complete. Then repeat this for the D drive.
Disk Cleanup and Defrag should be carried out approx. once every month to keep the computer operating at its best.
Aug 29, 2009 | Acer Computers & Internet
Hard drive thinks it is full
well..those ext drives can get confused..only way to assess this is to open the drive in the finder, and see how large the folders are..
Apr 27, 2008 | LaCie (300770) 250 GB Hard Drive
Hard drive shows full even after erasing 120 hours.
You should empty the recycled bin in the system and delete all temporary files on it.
Jan 10, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
ASUS U36J SMB PC Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
