Question about Kenmore 44102 Front Load Washer
Washer Machine does not work properly.
I have a front load washer machine that is one year old. I load the machine, select the cycle and pull out the button to star it. So far it work fine two minutes later when it empty the water the timer does not move from that position no matter which cycle I use. To use it now I have to stay there and move the timer forward every time stops. Any suggestions will be much appreciate. Thank you MR
    President:
  • 878 Answers
MR, Im assuming that your model starts with 417-44102. There could be a number of problems here but lets start with the drain pump itself. On this model, even though the tub looks empty there could be water under the basket. There is a pressure switch that will not allow the unit to spin if it detects water in the tub. I have found on many occasions that the pump has debris in it preventing a full drain. If you drop the bottom panel you will see the pump on the right side bottom. Get a pan, remove the hoses and clean out the debris. Another thing is you want to make sure that the hot and cold water are turned on to the washer, it will not advance if they are not turned on. If these areas check out ok, then some detailed tests will have to be made on the motor controller. Catriver...post back
Posted on Aug 14, 2006
My washing machine has started beeping during the wash cycle - why?
Try running the same wash cycle with no clothes in the machine, just the water.
If it does not beep you are overloading it or the load is unbalanced.
Dec 20, 2015 | Hotpoint Aqualtis AQ113F497E White 595 mm...
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Cloth too wet when washing cycle complete
When a front load washer is not spinning properly (it is very, very hard to overload a properly operating front load washing machine) you have a problem that can not be solved easily. Besides making sure the washer is level and stable (no rocking on its feet), changing the controls on the front or making other adjustments will not fix it.
It will require a service technician to take a close look at it, open up the washer and possibly even listening to the machine as it washes, drains and (attempts to) spin.
I hope this information is helpful. I wish I had better news or more guidance.
Apr 20, 2009 | Washing Machines
L.G DIRECT DRIVE 7 WASHER / DRYER U.E ERROR CODE
My machine is doing just the same! It is about the same age as yours. I cannot believe this is it working properly, but the manufacurers are no help.
I am seriously thinking of getting rid of it, and would be loathe to touch an LG again.
Linda
Mar 29, 2009 | LG WM-2277HW Front Load Washer
Washing machine suddenly stopped working during cycle
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 01, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore 44102 Front Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
