Question about Southbend ES10SC Electric Single Oven
Electrical diagram 240 volt singal phase element
  • ronald speedy Feb 14, 2012
    how do you wire up the element
120v on bake element red wire and element wont heat up
the reason its not heating is because you will always have 120 volts on this red wire due to its being connected directly to one side of the in coming power source,its either that you lost the other 120 volts of power coming into the unit,a tripped breaker/fuse/etc. or the control board relay that supplies the other 120 volts to the element for a combined 240 volts needed to heat the element,if you have 240 volts to the connection to the unit then you either a bad control board or the Neutral incoming power wire could be burned off which you need to get 120 volts to operate the control board which operate the relay to supply the element with the required 240 volts to operate
Oct 27, 2012 | Jenn-Air JMW8530C Electric Double Oven
Stove is not getting hot or elements
sounds like you've lost one phase of your 240 volt power
Sep 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need wireing diagram single phase for blodett mark 5
I'll need the volts (120/208/240) single or three phase, model # & serial # plus your e-mail so I can send you the scan.
Rick
capt_rick1912@yahoo.com
Jul 24, 2009 | Ovens
We have a Vulcan Roast Oven VO008 and it is wired for 480 volt 3ph, can it be rewired to be 240 volt single phase?
It could be but, the expense of replacing all the 3 phase controls would cost more than what it would be worth. Sell it and use the proceeds to purchase a single phase unit or if you are wanting to use it in a commercial building, see if you can have 3 phase installed by your electric provider.
Jul 07, 2009 | Ovens
Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Jan 18, 2009 | GE Profile JT952 Electric Double Oven
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Hobart HEC40 208V to a 240V source
The only difference should be the elements. Consider installing a buck-boost transformer. It may be cheaper.
The Hobart part number for the 240 volt element assembly is --
# 342170-00002. Your local Hobart can get you a price.
Mar 08, 2008 | Hobart HEC501-208V Electric Single Oven
Southbend ES10SC Electric Single Oven Logo
32 people viewed this question
Top Southbend Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
Paul Bade
Are you a Southbend Oven Expert? Answer questions, earn points and help others
