Question about Nokia 6600
Sound of ear peace
When sound level is at maximum,it is harly hearable that ear peace is o.k I know
How to install ogg player in nokia 6600 phone
Posted on Oct 25, 2008
No sound
that means you ear piece is dead or its disconnected,
you just need to open your phone and fix your ear peace or speaker
Nov 08, 2013 | Sharp FX Plus
How can I increase the loudness of the CDs burned on the internal CD-RW drive?
You can use a free software audio editing and recording program called Audacity. Using this program load your stereo track(s) into Audacity, then look in the effects menu and select normalize. Make sure to set highest loudness level to 0 db, which is the maximum digital volume level. You can hear the difference in volume when you use the test button. If you can't still get enough over all volume level with the normalize feature then you will need to compress and limit the stereo track, but I don't suggest getting your over all loudness levels that high because it ruins and lowers the dynamics of your music. Another words when you compress and boost the over all loudness of your album then all your music is at the same highest audio level which is very ear fatiguing. It may sound better to you at first at louder volume levels but you will quickly learn to hate it over time because it does not sound natural. That is why most music today is all about loudness and ear fatigue. And because of the loudness wars going on today every Record company is trying to have the loudest album out there thinking it will sell more copies. It is all false baloney, it really should be about the quality and dynamics of your sound instead of how loud it is.
May 23, 2013 | Fostex MR16HD/CD Digital Recorder
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
The right earcup in my beats by dr dry solo hd is making a cracking sound when im turning it up and down
that is because you push all the air against the speaker. the air have to get oute somwere. i had the same broblem so i put a little peace of rubber between the ear cushion and the plastick part. so ther is a litte split. if jou has a good peace of rubber or some plastick soft foam en at the top, you just do\'nt see the split. but be carful he can drop in to the speaker. wen you\'ve don dhat you do\'nt heare it enymore if it is good. (my english is not vedry good, iam from holland) i hope it worked for you. :p
Jun 28, 2012 | Monster Cable Products Monster Beats Solo...
Sound at 50-70 is not that loud. we have another model same size and samsung that is extremely loud at 25.. i dont understand
Speakers sometimes become damaged when going at high levels from low levels and just switching like that..... This may be the cause for it to be kind of low.... Best not to turn it all the way up or it might just blow the speaker fully..... You may have a a volume limit set on it.... Check that, it might be not allowing your speakers to play any louder.... Otherwise, it is best not to have your speakers blaring, just have them kind of low, and your ears will adjust.... People lose hearing when they have their TV's turned all the way up and all loud... Plus it just kind of disrupts the peace of a home :) Good Luck :D
Jan 08, 2011 | Samsung LN32C350 32 in. TV
Cant hear out of my ear peace
sir check the ear peace in other cell phone [or]service the phone ear plug in the service center.and then you can hear ear phone..........
Nov 19, 2010 | Motorola Mobility i580 Cellular Phone
The speaker on my ipod plays even when my headphones are plugged in. How do i turn off the internal speaker?
un plug ear buds
reset ipod by holding menu and center at the same time for 30 seconds till you see the apple logo - - then reconnect ear bus make sure they make a clicking sound and there is no gap
play a song to test
Apr 05, 2010 | Apple iPod nano
My mp3 worked fine, but all of a sudden my sound is not as it should be. I can hear the music quite fine, but the voices aren't hearable. Sometimes you can hear a voice clearly on some songs, but mostly it...
The earphone jack inside the player has broken the 'Ground' pin off the circuitboard. The jack needs to be resoldered. This does take an experienced technician with watchmaking skills.
Mar 22, 2010 | Sony Walkman Bean NW-E307 MP3 Player
BOSTON ACOUSTICS BA735 volume is LOWER than MAXIMUM LEVEL
OK, a few things here. First of all, what program are you using to listen to music? Some programs have an automatic volume leveling setting. If you're using Windows Media Player, it has one. Next, you should NEVER set any speaker/volume/amplifier knob to Maximum setting if you want to get any life out of your speakers. Speaker ratings are for consistent volume levels at a "clean" power level. When you turn any music source up past 80% you are pushing more distortion through the speakers that they cannot reproduce without self destructing. The human ear cannot hear this, and the volume gain is minimal. Next we'll talk about that your dealing with a combination of power levels compiling into an amplifier that may be taking in more than it can aptly amplify according to it's power multiplier scheme to increase the volume at the speaker level. If you've got everything maxed out, you're probably just pushing it all WAY too hard. All over exerted energy that is not being used productively will end up in generating heat and distortion. Those are your 2 biggest enemies when it comes to anything audio. Distortion tears voice coils and generates disruptive electrical currents, and heat destroys circuitry and components in amplifiers. The times where they jump up in volume, just look at that as borrowed time until they blow. If you want louder, get a better or more powerfully rated set, and still, NEVER turn it up past 80% if you want it to last.
Jun 09, 2009 | Boston Acoustics BA735 Computer Speakers
SGH-G600
thanks for that the sound on my g600 is much louder now and my music is louder too great thanks alot
Nov 04, 2008 | Samsung SGH-G600 Cellular Phone
Nokia 6600 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
