Question about Whirlpool Dryers
Whirlpool LER5620KQ1 wont heat
Dryer won't heat don't have electrical testers have to change from 4 prong plug to 3 prong dryer runs but no heat don't know if it is the outlet or a relay in the dryer the heating unit looks good.
Master_Tech
  • 770 Answers
SOURCE: changing four prong dryer to three prong outlet
use the ground on the machine.....There are 3 wires on the terminal block if you notice there is a grounding strap off the center post this will act as your ground to the machine back in your panel box the center post leads to ground anyway the other 2 are hot leads (240vac) use the 3 post you will be fine. you will be grounded let me know if you have any problems
Posted on Feb 19, 2008
  • 3 Answers
SOURCE: Install 220 outlet for electric dryer or trade it for gas dryer?
Thanks for all the input!  We reached a compromise in hiring an electrician who was willing to come out today and install the connection for half what everyone else quoted...on a Sunday!  The laundry piling up in the corner was very persuasive in convincing us that your advice (in the end, we'd need a professional no matter which way we went) was prudent.  Thanks. jersey p
Posted on Sep 14, 2008
jsrock516
  • 5911 Answers
SOURCE: changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Posted on Nov 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
frcs68
  • 1605 Answers
SOURCE: How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Posted on Apr 23, 2009
I have a maytag MDG40000Bww that doesn't heat
Start with the electric wire on the back of the machine. You have either a 3 prong or a 4 pronged electric plug.
Find a testing instrument and determine if two of the wires have 110 volts coming to them.
On a 3 pronged one ( the "L" shaped one) is the ground.
One a 4 pronged one, the round one and the "L" shaped ones are both ground.
The other two should each show 110v.
If all this tests well, we'll need to go inside the machine.
Your dryer has from 3 to about 10 things to check with an electrical tester.
You will be taking the wire connections off the heating element and all the thermostats one at a time and checking them to see which one shows " a problem", meaning electricity will not pass "through" them.
Also look for wire connectors that have burned in two.
If you need help here, please find someone who can show you how this is done.
Be blessed.
Jan 31, 2013 | Maytag Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
How do you change a 4 prong dryer plug down to a 3 prong power plug
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
Sep 05, 2010 | Whirlpool LER5636P Electric Dryer
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
