Monitor is dark when on but is flicking as though its trying to come on but fiddle about with the connection at the back of computer & it comes on ,this happens on analogue & dvi connection
  • nigelpilk Oct 25, 2008
    have tried the monitor on a friends computer its exactly the same ,time for a new monitor i think.Thanks anyway.
  • 94 Answers
Hi nigel
firstly i would change the lead from your graphics card to your monitor (borrow one from a friend if possible)if this solves it then fine if not, switch off your pc and disconnnect the cable from the graphics card end.open up your pc and identify you graphics (assuming its not onboard)remove retaining screw and remove from the slot(please note that some slots have a small plastic lever that needs lifting before the card is removed) After removal clean both the slot connectors with an alcohol based approved fluid and the cable pins also use a small brush of th nail vatnish type to clean the motherboard slots then replace refit the card back in its slot and reconnect
If the graphics are onboard (no card)then you only need to clean the the cable connector pins at the rear of the pc
Posted on Oct 25, 2008
  • Andy Bathgate
    Andy Bathgate Oct 25, 2008
    Endust for Electonics is a good example of a cleaning fluid
My monitor is on but the backlight is off. When you swicht the monitor at first, the lights come and go. I did check the inverter side and i fund out that pair of the driver transistors were dead. I did...
When you replace the transistors you should change all 4 of the C5707 transistors. You also need to resolder all of the connections to the 4 output transformers and the 4 output plug connections. If you did not resolder the these additional connections then the new transistors you install are more the likely dead now. The solder joints can crack because of the current and this causes the circuit to pull more amps than the transistors can handle. The new ones will blow within 2-3 seconds if you did not resolder the other connections.
Sep 23, 2012 | Dell E173FP 17" LCD Monitor
Monitor no signal
Sounds like the Monitor cable has come out either at the back of the computer or at the back of the monitor. try fiddling with them as this is generally the only cause of this message. The only other cause is if you computer is in fact not turned on :)
______________________________________________
BlueTiger Business Web Hosting
Jun 22, 2010 | Acer AL1916W 19" LCD Monitor
Acer screen keeps flicking on and off
Ok, that seems to be a problem with the monitor itself, which is most of the times. Try connecting the same computer to a different monitor. If you happen to have a laptop, try connecting it to an external monitor via video cable (such as vga or dvi connector). Good luck.
Jan 03, 2010 | Computers & Internet
Monitor comes up white on computer start up
see if you have bent pins on cable.
Aug 19, 2009 | X2Gen MW22U Monitor
Fuji 17" monitor Stays dark after power on.Power light on.
Connect it to a friend's laptop computer. If it does not work on that computer, it is "dead". If it does work on that computer, your monitor is OK, but your computer has a "video" problem.
Jun 08, 2009 | Fuji Computers & Internet
Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
May 21, 2009 | ViewSonic VG2230WM LCD Monitor
VA720
You could possibly have 2 problems with your monitor, though they are more then likely linked.
The Viewsonic monitors (like most) end up with buldging capacitors after several years use. This is typical of most equipment these days.
You can either replace the capacitors yourself or get in contact with someone local to you to have it done.
The reason I say there could be 2 problems that are linked is the fact when your screen does finally come on, it flicks the screen up for a second which would normally indicate a problem in the inverter circuit.
Because of the power fault though I believe it is more likely the one fault causing two problems.
With the capacitors failing, the voltage inside that powers the internal video board are not stable. That is what causes it to behave as it is.
On the homepage of this site you can use the Repair Service section (on the left side about half way down the page) to find a local repairman if that is the route you want to go.
Apr 19, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor keeps flicking in and out
AbandohE,
Make sure all the connections in the back of the monitor are connected properly. If all are and problem presists, it is probubly cheaper to buy a new one than to get it fixed.
Best of luck!
Dec 17, 2007 | Computers & Internet
LCD flicks on for a second, and then switches off
see this post
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Sep 11, 2007 | BenQ T701 TFT 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
