Samsung WF337AA Front Load Washer Logo
Posted on Oct 25, 2008
Error Code 1 on samsung fuzzy
When I turn my Samsung fuzzy washer on, it sounds like it is trying to drain, not fill up, and it comes up with an error code 1. I would appreciate any help on this.
A
Anonymous
Samsung front load washing machine 5E Error code
If your Samsung washer is in the middle of a drain cycle and the 5E error code shows on your washers display, it means that the water is not properly draining out of the washer. Something may be clogged, jammed, or blocked and thus preventing water from draining out of the washer.
https://removeandreplace.com/2016/11/03/samsung-washer-displays-error-code-5e-message-how-to-clear-error/
3answers
Washing machine drain problem
Here's a few instruction's How to Diagnose Washing Machine Problems
Step 1:
If the washer won't start, check the power cord or reset the circuit breaker depending on the issue. It may be overheated and shut off temporarily. Let it cool for 30 minutes, and if it still won't start, call a professional.
Step 2:
If the motor transmission failed or the drive belt has broken, these need the assistance of a professional.
Step 3:
If the washer won't drain, clean out the drain hose and straighten any kinks. If the drain hose fits too tightly in the standpipe, adjust it to allow for a minimum of 1.25 inches for airflow so water can drain.
Step 4:
If the washer won't fill or fills slowly, turn the faucet handles counterclockwise as far as possible. This is usually the result of partially open faucets.
Step 5:
Call a profession if the washer overfills. This means the water-inlet valve or switch is defective.
Kindly regards,
-micromaster
micro & yakman unltd.
Samsung clothes washer wa422prhdwr error codes please let me know what to do
TIP 1: Most error codes that display are related to installation, maintenance, and general use such as washer not being level, not cleaning the debris filter, not cleaning the inlet water supply mesh filters, and using too much detergent.
TIP 2: If your Samsung washer will not start, be sure the Delay Start function has not been activated. When the Delay Start is in use the display will show a number followed by an H (1H, 2H, 3H). The Delay Start icon will be illuminated. (The Delay Start Icon looks like a stopwatch)
SAMSUNG WASHER FAULT CODE: nd
SAMSUNG WASHER ERROR DEFINITION = no drain
If "nd" is showing on the display, it is an indication of a no drain condition.
HOW TO REPAIR/CLEAR ERROR?: This is caused by the debris filter being clogged or the drain hose installed improperly. Make sure the drain hose is not pushed too far into the drain/stand pipe. A unit that is not level, unbalanced, or overloaded may not drain properly also. Drain pump could be faulty. (nd error code repair here)
SAMSUNG WASHER FAULT CODE: nF
SAMSUNG WASHER ERROR DEFINITION = washer not getting enough water
If the machine is not getting enough water, a "no fill" (nF) error code will be displayed after 16 minutes of trying to fill. This does not mean there is a defect in the unit.
HOW TO REPAIR/CLEAR ERROR?: Be sure the water valves are fully OPEN. Verify the door is tightly closed. Verify the washer is plugged in. Check the fuse or reset the circuit breaker. Verify the debris filter is not clogged. How to clean the debris filter. Top Load washers do not have external debris filter access. Water inlet valve may be faulty. (nF error code repair here)
SAMSUNG WASHER FAULT CODES: DC or UC or UE
SAMSUNG WASHER ERROR DEFINITION = unbalanced load or board voltage error
This error represents an unbalanced load error or a main PCB (main board) voltage error.
HOW TO REPAIR/CLEAR ERROR?: Turn off the washer and open the door. Verify the washer is not overloaded and redistribute the load. Verify the washer is level. If the washer has Calibration Mode, re-calibrate the washer using your users manual or find one online. (dc error code repair here)
SAMSUNG WASHER FAULT CODE: SUDS
SAMSUNG WASHER ERROR DEFINITION = over-sudsing condition
If your washing machine has the word "SUDS" on the display, it has detected an oversudsing problem, and will stop for a short period to allow the suds to dissolve. This error code is usually caused by excess detergent or the wrong type.
HOW TO REPAIR/CLEAR ERROR?: Use HE (High Efficiency) detergent. This detergent is made for high efficiency front loader washing machines. HE detergent has high efficiency cleaning with low sudsing. Non "HE" detergent normally have high sudsing properties, and will cause excessive amounts of suds in your washer. If you are already using "HE" detergent and your washing machine is displaying the "SUDS" error code, you are using too much detergent.
SAMSUNG WASHER FAULT CODES: 8e or 8e1 or 8e2
SAMSUNG WASHER ERROR DEFINITION = connection error on circuit board
The 8e error represents a connection error on the washing machines main circuit board.
HOW TO REPAIR/CLEAR ERROR?: If 8e, 8e1, 8e2 is displayed on the washer check connections to main board. Check wire harness connections.
SAMSUNG WASHER FAULT CODE: FE Diagnostic Code
SAMSUNG WASHER ERROR DEFINITION = fan motor - main PCB - fan blower fault
The FE error represents a fan motor, main PCB, or fan blower fault.
HOW TO REPAIR/CLEAR ERROR?: Troubleshoot the above parts and replace as needed.
SAMSUNG WASHER FAULT CODE: dC Diagnostic Code
The dC error represents an unbalance load or a cabinet bump has been detected during the spin cycle. This prevents the drum from spinning over 400 RPM.
HOW TO REPAIR/CLEAR ERROR?: Verify the unit is level. During the spin cycle, press on each corner of the machine. If any one corner moves, the machine is not level and needs to be leveled. Adjust the unit for vibration. Cut power to the unit by unplugging it or switching it off at the circuit breaker for 1 minute then restore power. Press the power button to turn on the unit and see if the error returns. If the error returns, troubleshoot issue or service is required. If the error does not return, the issue has been fixed. (dc error code repair here)
SAMSUNG WASHER FAULT CODE: 5E
SAMSUNG WASHER ERROR DEFINITION = drain pump problem
The 5E error code appears when there is an issue with the drain pump. This can occur because of a drain pump or Main PCB malfunction.
HOW TO REPAIR/CLEAR ERROR?: This happens when the debris filter is clogged or there is an issue with the drain pump. How to clean the debris filter.
SAMSUNG WASHER FAULT CODES: 4E or 4E1 or 4E2
SAMSUNG WASHER ERROR DEFINITION = water supply issue
When 4E, 4E1, or 4E2 are displayed, this represents a water supply error due to one or more of the following:
HOW TO REPAIR/CLEAR ERROR?: Possible improperly installed water supply hoses or leaking hoses. Make sure both supply hoses are connected to each water source - Hot to Hot and Cold to Cold.
SAMSUNG WASHER FAULT CODES: bE or bE1 or bE2 or bE3
SAMSUNG WASHER ERROR DEFINITION = button on control panel sticking - faulty main PCB relay
The bE, bE1, bE2, and bE3 error codes represent a button on the control panel being held in or sticking for too long, or a faulty main PCB relay.
HOW TO REPAIR/CLEAR ERROR?: If any of these errors are displayed, you need to troubleshoot the issue, replace the main control board or panel, or service is required.
SAMSUNG WASHER FAULT CODES: PF or 9E or 9E1 or 9E2 or 2E
SAMSUNG WASHER ERROR DEFINITION = malfunctioning main PBA - power faults from electrical power
These error codes represent a malfunctioning main PBA or power faults related to an electrical power supply that is incompatible with the Samsung washing machine.
The electrical power requirements of Samsung washing machines are:
HOW TO REPAIR/CLEAR ERROR?: Be sure you have a 3-Prong grounded 120 volt 60 Hz approved electrical outlet. 15-amp fuse or comparable circuit breaker is a requirement for all Samsung Washing Machines.
SAMSUNG WASHER FAULT CODES: AE or AE6
SAMSUNG WASHER ERROR DEFINITION = communication errors sub and main PBAs - main and inverter PBAs
AE and AE6 represent communication errors between the sub and main PBAs or the main and inverter PBAs.
HOW TO REPAIR/CLEAR ERROR?: If either of these errors is displayed, troubleshooting is needed or service is required.
SAMSUNG WASHER FAULT CODES: 3E or 3E1 or 3E2 or 3E3 or 3E4
SAMSUNG WASHER ERROR DEFINITION = motor or hall sensor error
The 3E error code represents a motor or hall sensor fault.
HOW TO REPAIR/CLEAR ERROR?: Reset the washer by unplugging it for 30 seconds. If the reset does not work, and the error code returns, check motor and hall sensor or the washer needs service.
SAMSUNG WASHER FAULT CODE: CE
SAMSUNG WASHER ERROR DEFINITION = temperature sensor problem
The CE error code represents a malfunctioning temperature sensor.
HOW TO REPAIR/CLEAR ERROR?: When this error is displayed, troubleshooting the temp sensor is needed or service is required.
SAMSUNG WASHER FAULT CODES: dE or dE1 or dE2 or DE or dS
SAMSUNG WASHER ERROR DEFINITION = door switch problem
The dE, dE1, and dE2 errors represent a door switch malfunction.
HOW TO REPAIR/CLEAR ERROR?: Power off the washer. Verify that the door is closed completely. Start another cycle. If the error is displayed again, troubleshoot the door switch or service is required. If the error is not displayed, the door was not closed completely when the first cycle started. (dS error code repair here)
SAMSUNG WASHER FAULT CODES: HE or HE1 or HE2 or Hr
SAMSUNG WASHER ERROR DEFINITION = heater error or temp sensor error
The HE, HE1, HE2, Hr represent a heater error or a temperature sensor error.
HOW TO REPAIR/CLEAR ERROR?: When these errors are display, the heater and temp sensors need to be checked or service is required.
SAMSUNG WASHER FAULT CODES: OE or OF
SAMSUNG WASHER ERROR DEFINITION = water overflow
The OE and OF errors represent an overflow error caused by either a malfunctioning water level sensor, a damaged internal water supply hose, or a malfunctioning water supply valve.
HOW TO REPAIR/CLEAR ERROR?: Check and troubleshoot the water level sensor, water supply hose, and water supply valve.
SAMSUNG WASHER FAULT CODES: tE1 or tE2 or tE3
SAMSUNG WASHER ERROR DEFINITION = temperature sensors
The tE1, tE2, and tE3 errors represent malfunctioning temperature sensors.
HOW TO REPAIR/CLEAR ERROR?: Check temp sensors and replace as necessary.
SAMSUNG WASHER FAULT CODES: NF2 or 4E2 or 4C2
SAMSUNG WASHER ERROR DEFINITION = washer filling with very hot water
This error is displayed when the washer is filling up with very hot water. It is in place to protect delicate fabric that can be damaged by very hot water.
HOW TO REPAIR/CLEAR ERROR?: This error is usually caused by the inlet supply hoses being backwards. The hot water supply hose is running into the cold water inlet valve on the back of the washer. The cold water supply hose is running into the hot water inlet valve. As soon as the unit detects the temperature is too high, it will stop and drain. It will then try to fill again. Check water hoses and switch the hoses to the correct water valves.
SAMSUNG WASHER FAULT CODES: Eg or E9
SAMSUNG WASHER ERROR DEFINITION = software lock
The LO error represents a lock software error.
HOW TO REPAIR/CLEAR ERROR?: Unplug washer for 1 minute and see if that resets.
SAMSUNG WASHER FAULT CODES: Le or 1E or Ie or lE
SAMSUNG WASHER ERROR DEFINITION = Oversudsing - water level error
If you see the words/letters "LE", "Le", "1e", "1E", "le", "lE", "Suds", "SUDS", or "sUDS" on the display, it is an indication of "oversudsing" or a water level error.
HOW TO REPAIR/CLEAR ERROR?: This is almost always caused by using too much bleach, softener, detergent or non-HE detergent. You may also have a problem with the water level sensor. (Le error code repair here)
2answers
Error E1 for washing machine
AK Techno service is the best service center for repairing and service for all types and brands of washing machines.
For more visit our website. http://aktechnoservice.com/samsung-washing-machine-service-center-in-hyderabad
samsung washing machine service center in hyderabad...-bo0djorvxqfflml1tozu5o0f-5-0.jpg
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
I want to know what de code stands for on a SAMSUNG WA13F5S2UWW 13KG WH T LOADER Washing Machine
The error code is presented when a "child lock" error has occurred--you will see either "CL" or "DE". You can clear the error after the washer drains. This error condition prevents a child from drowning if he or she should fall into the tub. After the washer drains and the alarm has sounded, close the door, turn the power off, then back on. This instruction set comes straight out of the user manual. This user manual can be found at http://downloadcenter.samsung.com/content/UM/201408/20140828102900808/F500S_GOOD_DC68-03273M-02_EN_FA_NQ_20140512.pdf
3helpful
Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
2helpful
3answers
E1 Code - tried fixing it according to manual still won't work
The error code E1 = Water supply error -Not enough water entering the W/M.
Try check water supply line is on and not have any kinked.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
