Question about Home Security
Optiview Bought a used Optivew DVRH8 and need to reset the password. The unit works fine but the date/time is the wrong time zone and i cant set network up. Any idea how to reset the password on this one? I took the backup battery out for 10 miutes and that set the date back to midnight on Jan 1 2000 ... but still cant get in. Tried the default user and password (admin / 1234) but still nothing.
  • Jim Armstrong Feb 21, 2012
    Thanks for the options Dave. This DVR has no switch on the back although it does have one on the board, no matter what order i do the 'Switch, Power, Let go" sequence, it doesnt seem to do anything at all. This model has the user name "admin" but the password must be numeric entered from the camera select buttons. It is supposed to be 1234 by default but that is all Optiveiw would tell me. Because I didnt buy it from them, they will not help me. Any other ideas let me know.
    Jim
  • 488 Answers
Try the user as admin and the password as admin..
If my memory serves, there is also a master reset switch..
Look for a small hole in the rear of the case, power the unit off, press and hold a small pin into the hole to hold the switch in and then switch the power back on..
I know ya need three hands to do this...
If no hole is present, check inside the case on the board for the reset switch..
Posted on Feb 15, 2012
How do reset the time
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Date and Time Settings Pantech Marauder
Nov 01, 2015 | Pantech Cell Phones
Ive got a sentient 4 channel network dvr h.264,during the instillation i entered a password but now i cant remember it pls can anyone tell me how to reset it
Try following standard account passwords comes with the unit, I've had a similar problem 999999 worked for me.
power 999999, police 111111, admin 123456, guest 000000.
Oct 03, 2012 | Home Security
Have just bought an Elonex ebook colour 705EB and been trying to reset date and time as they are wrong... done as said on Manual go into Settings choose Time and Date setting... change the date and time...
Hope you read this message. I just noticed your message today on this site.
I bought an Elonex 705EB for my mum and had the same problem. It's not pressing the select key that changes the time. You must correct the time then press Menu button on yes (I had to press twice in row before it worked). I don't know why it works different from the manual. I found this out through a lot of trial and error!
Jul 26, 2011 | Computers & Internet
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio on CKS1850
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Mar 15, 2011 | Emerson SmartSet CKS1850 Clock Radio
I cant open my yahoo.mail
Check the time zone on your computer versus the time zone in the Yahoo profile they need to match as this could be synch error.
To check the time zone on your PC Double click on the clock in the lower right corner. Then Check the time date year, then time zone.
Sep 21, 2009 | Yahoo Messenger
Setting Date And Time
By Settings/Time and Date switch Time zone updating to Manual Only. Now you can set time and date below
May 31, 2009 | Samsung S8300 Ultra Touch platinium-red...
Cant change time on gps
the time and date should set it self when you turnit on, as long as the unit was designed for use in your area then it should set to the right time.
Apr 05, 2009 | Sony NV-U73T GPS Receiver
Wireless issue.
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE browser.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Log-in with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
For a more detailed first time install no software needed check this link:
http://www.dslreports.com/faq/14083
Enjoy!
please vote...
Feb 06, 2008 | 2wire 2700HG-B Router (2700HGB)
Wrong date and time
Your GPS receive its date and time from satellites. Take the unit outside and acquire a satellite fix in order to update your time and date. You can set the time zone and time display (12hr, 24hr, UTC) under the unit setting.
Jan 12, 2008 | Garmin nuvi 350 GPS Receiver
Home Security Logo
283 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
