Question about LG Refrigerators
Lg lrsc26925tt eR DH error. I know it's either the heat element, temp probe, or the thermistor but how do I measure them and does anyone have a picture of the components?
  • 60 Answers
SOURCE: LG Refrigerator
That stands for a defrost heater problem. Usually it's the defrost detect circuit that has a blown thermal fuse.
Posted on Dec 20, 2007
  • 27 Answers
SOURCE: where is this fuse located on the LG refrigerator is displaying a ER DH code error
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Posted on Jan 06, 2008
  • 489 Answers
SOURCE: LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Posted on Apr 29, 2008
  • 110 Answers
SOURCE: LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Posted on Jun 13, 2008
  • 1122 Answers
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Posted on Jul 07, 2008
Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
Feb 24, 2010 | LG LRSC-26922 Side by Side Refrigerator
Have a LG 3 door bottom freezer with error code Er dH. Was told by tech support to unplug for 10 mins. If this fails unit needs service. Is this correct?
dh means defrost problem.replace defrost control and element,behind freezer panel.dont forget to unplug fridge before you work on it
Nov 17, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG code ER DH, Defrost Heater or Thermistor?
Check for current flow through the defrost heater. If no current then replace the heater. If heater is OK check thermistor for correct operation. From service manual chart (their words not mine): ER DH is Poor defrosting. Indicates: Even though it is passed 1 hour since then
Defrosting , if Defrosting
sensor is not over 8°
Remarks: Temperature fuse Disconnection,Heater
disconnection, DRAIN Jam,
Poor Relay for Heater
Aug 11, 2009 | LG LFX25960ST Stainless Steel French Door...
Door display shows ER WITH A UPSIDE DOWN HP. I turn the power off and back on and the display goes back to normal but after several hours it goes back to where the only thing on the display is the ER PH...
That stands for "error defrost heater"
Even though the refrigerator has gone through a defrost cycle, if a temp sensor does not reach a set temp within an hour, that error will display. You may have a bad defrost heater, defrost relay, thermal fuse, blocked defrost drain,..... something wrong with the defrost system anyway.
Aug 03, 2009 | LG LFX25960ST Stainless Steel French Door...
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
Jun 13, 2008 | Refrigerators
Apr 02, 2008 | LG LRFD25850 French Door Refrigerator
Kenmore Elite Refrigerator error er dh
Great advice from medeer, I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
My refrigerator is 20 months old, just a few months past the warrentee,
Feb 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
180 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
