I need the wiring diagram for this saw.
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
SOURCE: Switch diagram
as u notice the terminal on the switch has 2 connection like a switch diagram to it.it has normally open & normally close contact. the normally close contact are for red & white wire & the other
contact are for 2 black wire which is normally open contact.hope it helps.
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
SOURCE: How to wire switch for Dewalt DW718 Type 1 mitre saw.
Does the switch not have color words on the back of it? They used to. Go to Dewaltservicenet.com and look up your model number and type number. Wiring diagrams will be found there. Lemme know. Please rate me
SOURCE: I bought a used dw708 miter saw. It makes an
i would think it is neccesary to strip it down, but obviously there are bearings gone allowing the shaft to move over and grind and screech,i think it will be all too obvious what you will need when she is stripped ,.
Testimonial: "Right on the money. The front bearing was mostly gone. Thank you."
