Question about Home Security
Access master garage door opener led blinking yellow?
  • 10 Answers
SOURCE: garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Posted on Apr 05, 2009
  • 3197 Answers
SOURCE: One of my garage door sensors is yellow while the other is green.
It means your sensors are properly aligned. Are you having a problem?
Posted on Jun 16, 2009
  • 244 Answers
SOURCE: clearing codes on liftmaster garage door opener with yellow learn button
you seem to be doing right thing, hold learn button for 10 seconds, this should clear out all coded items; keypads, remotes.
Posted on Jan 15, 2009
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: Access Master Garage Door Opener opens by itself
The most common cause of this is a bad wall control or the wiring going to it. The wall control goes bad from use and the wiring sometimes has intermittent short caused by the staples the installer used.
Posted on Jul 31, 2009
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Tip
2010 BMW 528XI Garage Door Opener Homelink Setup
**** >>> This setup I performed with my new 2010 BMW 528XI Garage Door Homelink and Chamberlain Garage Door Opener <<< ****
Chamberlain:
01. Power off or unplug the garage door opener motor power supply (which is mounted on ceiling of the garage) ;;;
02. keep the garage door opener transmitter in your hand (do not press any button at this time) ;;;
03. In your 2010 BMW 528XI Homelink button (which resides under rear view mirror) press the 1st and 3rd homelink button together for about 30-40 seconds (i.e., until the yellow light blinks fast) and when the yellow light next to the homelink button blinks fast release from pressing the (homelink) buttons ;;;
04. now hold the garage door opener transmitter closer (means within 2-4 inches) to the homelink button (either 1st or 2nd or 3rd) whichever you are planning to program to open the garage door ;;;
05. now press the garage door opener transmitter button and chosen homelink button (either 1st or 2nd or 3rd whatever you need) together ;;;
06. the yellow light (next to homelink button) initially may blink slowly but after few seconds (may be 10-20 seconds) will blink fast; once it started blinking fast release from pressing both garage door opener transmitter and homelink button ;;;
07. Now plug or power on the main garage door opener motor (which is mounted on garage ceiling) ;;;
08. On the main garage door opener motor (which is mounted on garage ceiling) press the "LEARN" button (once you press it may have yellow/orange color light; make sure the light is on) ; then within 30 seconds do the next steps #9, #10, #11 very carefully ;;;
09. go to your car and press the homelink button you programmed and hold it for 4 seconds and then release it --> 1st iteration ;;;
10. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 2nd iteration ;;;
11. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 3rd iteration ** important note; generally three iterations are not necessary; and steps #9, #10, #11 must be performed within 30 seconds ** ;;;
12. during one of the iteration you will hear "CLICK" sound one-time from Garage door motor (which is mounted on ceiling) and if you have light attached with it; it will blink once (** if you hear the CLICK sound and/or light blinks once**) then the particular homelink button is programmed ;;;
13. now press the programmed homelink button; the garage door will open or close (but always it will take 3 or 4 blinks in yellow light or 2-3 seconds before the garage door opens or closes and which is normal) ;;;
** Thats it, your 2010 BMW 528XI Garage Door Opener Homelink setup is complete ** ;;;
You can program rest of the homelink button the same way but following from the steps between #4 and #13 ;;;
Hope this steps will help you to program chamberlain Garage door opener in 2010 BMW 528XI Homelink. ;;;
** possibly the above same steps may work with other BMW 5-series cars homelink too (but I'm not sure) **
on May 29, 2010 | BMW 528 Cars & Trucks
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
Access Master M100 Garage Door Opener has quit completely - what does the 5X flashing yellow lights mean?
5 flashes means "Opener overheated/bad rpm sensor
". Let the opener cool down for 30min. Then try again. If that does not help then replace the rpm sensor. If that still does not help then have a garage door pro come out to have a look.
Jun 06, 2012 | Sears LiftMaster Home Security
I have a Chamberlane Lift Master Professional I went to open it yesterday and it would not open. When the button is pushed the unit just clicks and the controller light is blinking 5 times then pauses and...
The code it is flashing is "RPM sensor or motor overload." It is not a door sensor problem. The RPM sensor is a small circuit board just in front of the motor.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Jul 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
L.E.D lights at back constantly blinking, garage door won't open
If the LED is blinking randomly it is normal. If it is blinking rapidly you have interference from somewhere. To eliminate any interference start unplugging anything electrical and watch the LED. Some things will interfere that you wouldn't even think of like a heater in an aquarium. Check everything especially in the garage.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close with remotes
Yeh, read manual. Do both sensors have led lit. try aligning. you have safety beam problem,
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
291 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
