When I insert certain disks, nothing happens when i click on "Zip 100 (L:)". Help!!!!!!!!!! P.S. If you need it I am using the parralel port one.
SOURCE: Iomega zip 100 external
get new drivers here
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/cci/subproduct.php?p_prods=1&p_pv=1.1&prod_lvl1=1&p_sid=afeorVWi
SOURCE: Zip drive 100, USB won't read my files anymore
I had the same problem when using OS10. Zips only open on my Mac G4 which also has the Classic 9 operating system and zip files open on my older computer with operating systems.
SOURCE: Can not eject zip disk
I have the imoga 100 external zip drive and there's a pin hole on the front panel. that if you straighten a paper clip and stick in the whole, it should manually eject the disk.
SOURCE: Can't read specific Zip 100MB Diskette
Its probably a bad disk. The only way I have been able to fix these is to First launch disk utility THEN put the disk in. THEN run the utility. You have to do it in this order. The key thing here is utility has to be running first and then insert the disk "HOT"
Hope this helps!
SOURCE: When I insert a disk into the scsi zip drive it
Google-search 'IOMEGA CLICK OF DEATH'.
Their ZIP drives were famous for this untimely death.
help?
