Question about Refrigerators
Fridge freezer working but not fridge - Refrigerators
DEFROST TIMER FAULTY
Posted on Oct 25, 2008
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
Side by side freezer, fridge. freezer works
try to look for the fan inside your fridge, see if it is working, if not, have it replace
Nov 11, 2009 | Refrigerators
We have a freezer bottom fridge- the freezer is working but the fridge stopped working. We tried cleaning the vents and unplugging and re-plugging. It sounds like it's on but there's no cold air on the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.Make sure the fan is running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 29, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer works, fridge part does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Refrigerators
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Magic chef fridge not working
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be beginning of defros problem.
Jun 04, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer is working but fridge is not cooling
is the evaporator fan (in the freezer) running? if not you cant move the cold air from the freezer too the fridge. also make sure the return air duct is not blocked. air moves from freezer, through fridge and back to freezer.
May 25, 2009 | Haier RRTG21PAA Refrigerator
Refrigerators Logo
297 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
