Question about Kitchen Ranges
Electric Calrod heating burner gets too hot
I have a 4-burner GE Electric Range Model # JP 661V. Two burners are 6" and two are 8. Top left 8" burner gets too hot when turned and kept at any control position even at WARM. Other three burners are working fine. What is the problem? Is the burner bad? or Is it the control switch for the burner bad?
Switch is bad
Posted on Feb 14, 2012
Trying to identify an old GE electric range and find service manu
That is definitely an oldie, but a good one. I always pull each burner, remove the clips off the ceramic insulator, and replace one wire at a time. If you look at each burner control, they should all be the same ie. #1 is the same on each. There are usually only 3 wires on the small burners, and 4 wires on some of the dual coil larger burners. Also, on the back panel, there is supposed to be a wiring diagram glued to it. I may still have some parts for it if you need any.
Jan 09, 2010 | GE Kitchen Ranges
Broken glass top inset ''burner ring''
If you are referring to the bakelight material, this is an insulating compound and the burner still may work. I would not use this long term in this manner however. This material insulates as well as helping maintain an even heat transfer of the burner. Long term use, may cause damage to the cooktop. The burners are replaceable, but the prices vary depending on the size of the burner. The part numbers are as follows:
6" radiant heat burner - WB30T10129
8" radiant heat burner - WB30T10132
9" radiant dual heat burner - WB30T10133
You can view these parts at searspartsdirect.com under the "Cooktop" heading. You may find the parts cheaper at these other websites, by searching for them using the part numbers provided:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary at the other websites. Sometimes they may not carry the model number, but the part numbers are still listed.
If you have further questions, please post back and let me know. I hope this helps you.
Dec 22, 2009 | GE JBP65 Electric Kitchen Range
GE range two large burners do not work. The two small burners work OK. One of the large burners has an obvious break in the calrod. Could it have blown a fuse or circuit breaker inside the stove that...
Burners went bad, Replace them. You may also have to replace where they plug into. Come problem with electric stoves. Easy fix! You can purchase at lowes, homedepot, or any appl repair parts store.
Aug 22, 2009 | GE JBP30 Electric Kitchen Range
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Top burners and oven don't heat up enough-GE Spectra
the stove it's only getting 110 volts, that's what happen when it does not get enught power.
Dec 03, 2008 | GE Spectra JBP78 Electric Kitchen Range
Looking for Cause of Fault Code on GE Range top JP939
Have SAME EXACT issue - F113 on Left burner. Indicator says HOT and not even on. Called a service company (NOT GE SERVICE). They said the Element Radiant is no good and must be replaced. Part is quoted as $323.98 !!! What a rip off from GE !
Jul 02, 2008 | Cooktops
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
242 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
