Advent PC change DVD Drive
Advent PC cannot extract broken DVD Drive. is there a special tool required to depress the locating lugs?
  • 26 Answers
On almost all CD-Roms and DVD-ROMS there is a very, very small pin-hole on the disk drive door located, usually in the middle lower third of the door... but not always. When you find it you will need to do the following:
  1. Take a medium or large sized paper clip and straighten it out so at least two of the clips sections are straight.
  2. Put the straightened wire into the hole and push it gently straight into the hole until you feel some resistance. This is the release mechanism for the drive door and track lock.
  3. You then push firmly and steadily into the release tab until the door and track pop out. It only will pop out about a half an inch or a little less, but it isn't locked any more.
  4. Now you can use your fingers and pull the tray the rest of the way out to retrieve you media
I hope this will resolve your problem, Good Luck
Greased
Posted on Feb 04, 2009
How do I separate the impeller/basket housing from the motor in the Davey Silensor pool pump?
That big collar sitting between the pump and motor body unscrews in an anti clock wise direction when looking at it from the rear (of the motor). The collar may be on rather tight and there is likely some special tool available to help unscrew these big collars (but who has all these special tools).
In my case, with my SLS-200, I placed a block of hardwood resting on a collar rib and then carefully tapped the wood to loosen the big collar. It needed gentle tapping while moving the wood to other lugs before it was loose enough to undo by hand. The problem is that if you tap too ******* one lug, or tap for too long on one lug, the lug itself may break but the collar will still be OK and fully usable dispite a few broken lugs.
Note that there is a big O-ring that sits inside the collar so best to inspect it for damage and also ensure that the pump body and collar threads are clean and that the mating surfaces where the O-ring sits are free from scratches or debris (to ensure it wont leak when reassembled). A new big O-ring may or may not be required depending on it's condition.
Oct 06, 2015 | Pool & Spa
Tip
How to Boot and Install Windows 7 from a USB (even without an ISO file)
While searching in internet I found 3 ways of doing this thing. I will explain all of them here.
1st Method: (The simple one) * Requires a valid ISO image.
Download Microsoft's official tool to install Windows 7 from your USB stick.
Links below:
From CNET: http://download.cnet.com/Windows-7-U...?tag=mncol;pop
MS Store: http://images2.store.microsoft.com/p...B-DVD-tool.exe - Microsoft Store Info Here.
To install the Windows 7 USB/DVD Download tool:
  1. Click to open the Windows 7 USB/DVD Download tool installation file.
  2. When you are prompted to either save the file to disk or run it, choose Run.
  3. Follow the steps in the setup dialogs. You'll have the option to specify where to install the Windows 7 USB/DVD Download Tool.
Note: You need to be an administrator on the computer you are installing the Windows 7 USB/DVD Download tool on. The tool requires the Microsoft .NET Framework version 2.0 or higher.
2nd Method: (Reliable method, Supports multiple types of image files) Requirements:
Now insert the USB drive, run UNetbootin, and select Disk Image as ISO( or select the type of image file of which you have).
Browse your local drive for Windows 7 that you downloaded and click Open.
Now Select Type as USB and choose the drive.Once done, it will look like a bit similar to the screenshot shown below.
unetbootinmainwindows77.png Click OK and it will begin extracting all installation files to the USB drive. The whole process will take some time(10-15 minutes), so have patience.
Once the installation is complete, reboot your computer. Now while your system is starting up press the appropriate button(usually F1, F2, F12, ESC, Backspace, or Escape) to bring up Bios Boot Menu. Change the startup order to boot USB by default, usually you will have to press F6 to move the selected USB device on top. Once done, save changes and restart the system.
3rd Method:( Try this if both above methods are not working) Using Ultra ISO application.
1) Download the free UltraISO trial by clicking on this
2) Start UltraISO as administrator
3) "Burn" the iso image to the USB stick by following these steps
With UltraISO:
- Open the image of Vista/Win7 with UltraISO
- Under BOOTABLE tab choose WRITE DISK IMAGE
- Choose your USB stick under "Disk Drive"
- Choose a method (It's recommended to use USB-HDD+)
- Press Write
PS: Make sure to change your BOOT order in BIOS to boot from your USB drive first.
on Oct 06, 2010 | Computers & Internet
I am having trouble getting the hub or drum off the rear wheel of my 06 fucus dose this require a special wrench or tool?
Does it have one of those special locking type lugs?They are usually only on one nut.If it doesn't,spray the lugs with WD-40 or something similar.If you have a question about the locking lug nuts please do write back.Good luck!
Jul 24, 2010 | 2006 Ford Focus
On a 2003 Saturn Vue can I replace an individual tire stud or do I ned to replace the entire hub?
the wheel LUGs are pressed in .. you can replace one or more but it requires a special tool (press) to remove and install the new one... your local auto parts store may have one that you can rent or if you can bring in your part ..they may be able to remove the old one for you .. often free or a small charge .... in a pinch you can hammer a broken lug out if you are careful not to mushroom it or damage the wheel bearing . ... ..
Apr 11, 2010 | 2003 Saturn VUE
To change the dvd drive
Take the System to an Apple Authorized service center to replace the drive.do not try it by your self because it require special tools to open
Apr 08, 2010 | Toshiba Computers & Internet
There is a lug on the tire that cannot be removed by the standard lug-wrench. What is the socket required to remove that one lug?
That is a special wrench that people usually keep in the glove compartment or another secure place. I keeps potential thieves from being able to steal the wheels unless they have the special wrench tool. If they are Mitsubishi wheels, check with the dealer or the brand name of the wheels on there if you don't have the special tool.
Good luck
Dec 04, 2009 | 1993 Mitsubishi Diamante
How can I burn a DVD disc
Download XP_CD-DVD-Fix.zip and save this file to your hard drive. Navigate to where you saved it and double click the file to extract the contents. Locate the EXE file you extracted and double click it. A confirmation dialog will appear when the script is done. You may need to reboot for the change to take effect.
here is the download link : http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Nov 08, 2009 | HP Pavilion s7310n (EN996AA) PC Desktop
I can't find the "key" or "star tool" to remove the wheel
Sounds like a previous owner replaced some of the lug nuts with security type which require a special adapter to fit the lug wrench.
A tire shop or the car dealer might be able to supply the adapter.
Jan 04, 2009 | 2005 Chrysler Town & Country
How do I remove the center lug on wheel?
On our Mazda3 the special lug removal tool was in the glove box in a blister pack with spare lugs. After having the car serviced the tool dissapeared and after searching I found it in the lug removal vrench where the dealership mechanic left it. Hope this helps. Alex
Nov 23, 2008 | 2005 Volkswagen Touareg
Spindle for cd drive broken
I'd suggest you change the drive,, DVD DRIVES FOR LAPTOPS are usually standered parts Take the drive out and buy one and replace it. I dont think you laptop might require a special drive Laptop usually carry standered drives meaning any one should work.
Dec 26, 2007 | Dell (M6790) DVD RW Burner
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
