Question about Toshiba Computers & Internet
Manual for toshiba IPT2010-SD
How to hook up with modem and wireless router
cyrylthewolf
  • 143 Answers
SOURCE: hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Posted on Nov 11, 2007
Eddie333
  • 176 Answers
SOURCE: can't get a wireless router to work with a speedstream 4200
From the telephone outlet the dsl line (telephone line) connects to the dsl jack of the Speedstrem 4200 DSL Modem.
From the modems open port you connect one Cat5 network cable into the port (in back) of the Belkin N Wireless router.
For wireless internet connection to begin you must also do a wireless set-up on the software side of the Belkin router or through their web interface.
Posted on Jan 05, 2009
SOURCE: Belkin G Wireless Router Connection problem
Sounds like a faulty router or issue with the firmware if it is unaccesible, your best solution is to factory reset the device and try again.
Regards,
Kris
Posted on Mar 18, 2009
  • 154 Answers
SOURCE: 2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Posted on Apr 24, 2009
spincycleus
  • 62 Answers
SOURCE: WHAT ARE THE STEPS TO
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Posted on May 01, 2009
How to hook up my ps3 to my toshiba pcx2500 router and keep my computer hooked up as well?
If your computer is already connected connected then connecting the PS3 will not stop the computer from connecting to the router.
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :-
http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 03, 2011 | Toshiba PCX2500 (pcx2200) Modem
I cant hook up my d link 150 up to my toshiba sattelite laptop. i have dsl modem and i dont wanna mess it up.
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 09, 2011 | D-Link Wireless N 150 Home Router 4Port...
I need connect a wirelees router a this modem,u help me plzzz
most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
Feb 28, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Set up difficulties
You sure can. Start w/ the Comcast modem as long as it is NOT a USB type and hooks using a CAT-5 cable (regular network cable). Hook the comcast modem to the WAN port of the wireless router. On the back of the wireless router use the normal 1-4 extra LAN ports to hook other computers or the SD208 switch to it and other computers from there.
Word of advise if using Wireless Router, be sure to read manual and set a KEY for your network to secure it from unwanted outside use.
Apr 03, 2010 | Linksys SD208 8-Port Ethernet Switch...
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
How do hook up a wireless laptop to a router and
Are you trying to install the router.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Feb 04, 2010 | Belkin Computers & Internet
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Setting up a wifi router
Configure the router first using the desktop. Make sure the modem is connected to the Internet port of the router and the desktop to port 1. Just run the setup CD that came with the router and it will guide you through the setup process. You can also try to reset the router first by pressing the reset button at the back for 10 seconds then unplug the power to the router and the modem, wait for 30 seconds. Power on the modem first and wait for the lights to stop blinking, then the router. check if the internet works hardwired.
Hope that helps.
If not, tell us more. Who is your ISP (Internet Serivce Provider)? Is it a cable or DSL?
Jul 24, 2008 | NetGear WGT624 Wireless Router
Wireless router
No, but if you hook up a computer connecting to the internet through that phone line to the router, i think you can share that internet connection with the pocketpc. Reply With Quote
Sep 11, 2005 | Toshiba e400 Pocket PC
Computers & Internet Logo
630 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
