Question about Pentax ZX-5N QD 35mm SLR Camera
Help me with camera Pentax M2-5N
Hi there, I need a solution with PentaxM2-5N. it dosen't snap and It just makes a noise when I trigger...I have changed the film and batery but it didn't help.It doesn't focus, It hasn't been used for a while. I'll be waiting for some help. Thank you Adi.
  • Olivia Stewart
    Olivia Stewart May 11, 2010
    Does this camera have auto zoom, or do you have to rotate the lenses?
3 Suggested Answers
  • 206 Answers
SOURCE: Pentax zx-50 Shutter Problems?
I really think this is the classic zx - 50 shutter motor problem : small motor on the side of the mirror box is not cocking the shutter . This is very repairable but unfortunately it requires fair amount stripping down of the camera to get to the fault and so you will have to take it in for repairs.
Posted on Sep 03, 2007
  • 206 Answers
SOURCE: Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Posted on Sep 17, 2007
Is it OK to use a Pentax AF500FTZ flash on-camera with a Nikon D70s? Is the trigger voltage going to be a problem? It looks like one can use a Nikon flash on a Pentax DSLR without problems.
The brands use the flash contacts to communicate to the camera. They do not make their flashes compatible with other brands. Don't mix brands. Even if trigger voltageis not an issue, the TTL and AF is not going to function.
Mar 24, 2011 | Pentax AF-500 FTZ TTL Flash
Pentax K110d flash trigger problem, I have 2 flash trigger strobes set up and a flash on the hot shoe of the camera, but with shutter release the trigger strobe lights fire but do not show in the pic, only...
Your camera uses a PTTL flash system. That means the flash on the camera fires a "pre-flash" to set the exposure and then the main flash. Your flash trigger strobes are reacting to the pre-flash and firing before the shutter activates. This all happens in a millisecond.
Oct 25, 2010 | Pentax K110D Digital Camera
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
Dec 08, 2009 | Pentax ME Super 35mm SLR Camera
Shutter won't click, Films Winds back in canister.
Shutter motor is bad and needs replacement.
Apr 01, 2009 | Pentax MZ-M 35mm SLR Camera
What is the trigger voltage for Pentax AF 500FTZ
When using a digital camera with a flash unit of unknown trigger voltage, you are risking the life of your camera. Excessive trigger voltages can disable the cameras internal circuitry to the point where it is totally beyond repair.
I do not have, in my files. the trigger voltage for the specified flash unit. I only have the specs for larger portables and studio flash gear.
A simple test , however, will reveal the exact trigger voltage. If you have a multi-meter or a DV voltmeter with a 250 VDC range (just to be in the safe side) you can preform this test at home or an electronics service technician can do it for you in a few minutes.
The test lead are placed across the synch contacts on the foot of the unit or plugged into the sunch socket if the flash unit has one. If the reading is more that 4 or 5 volts you can still safely use the flash with the aid of a protector device which goes in between the flash and the camera. Theses are available at better camera shops and dealers.
Nov 16, 2008 | Pentax AF-500 FTZ TTL Flash
Pentax ME shutter triggered just from advancing film
the shutter locking lever is sticking. time for a clean, lube & adjust.
i would take, or send this fine rugged camera to a reputable camera repair shop, have an estimate for a cla.
This model pentax is made with very little plastic and will last a long time with an occasional cla.
Apr 02, 2008 | Pentax ME Super 35mm SLR Camera
Strange electrical noise after i take a pic
this tipe of electrical sound can be a electrolitic condenser that is defective.
i can repair it if you are in europe.
Jan 24, 2007 | Pentax 645N Medium Format Camera
Pentax ZX-5N QD 35mm SLR Camera Logo
41 people viewed this question
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
