Question about Rio CE2100 MP3 Player
Battery My computer doesn't recognize my rio mp3 while I try to reformat it because of an Upgrader problem. I've tried resetting it and downloading new firmware and nothing changes. One source said to reinsert battery. So how do I get to the battery without tearing the whole thing up?
Hit it and if that doesnt work hit it some more show it tuff love i've had mine for about 2 and half years and it craps out every now and then but if i throw it hit it and shake it it knows whos boss and will work for you. and if it breaks for good never buy a new one...ever.there shit.
Posted on Apr 22, 2007
Thanks alot for failing to mention that the wires connecting the battery are SOLDERED. I patiently pried and realized what u meant...u have to "peel" back the tabs so they don't relock into place...and MOST of the tabs are on the sides except the hardest 1 (of 2) which is right behind the volume dial... There are 2 small tabs near the the hole for the earphones...one on each side..directly behind these two there is a tab..kinda pain to get to...off to side of it though..behind the volume dial is ANOTHER tab...pain to work...then on each side and bottom there are 2 tabs (2 right hand side, 2 LHS, 2 bottom) so a total of 10 tabs. My Rio CE2100 is stuck in upgrader/recovery mode too...so i figured nothing to lose... Just know before u tinker.
Posted on Dec 29, 2006
Honestly the RIO ce2100 is a pain to get into, but there is a possibility if you have a set of jeweler's screwdivers and a great deal of patience. First, take of the chrome plate off the top (there are clips at the sides), and then pry the bottom up just a bit. You should see metal clips holding the thing together. Pry them towards you and work your way around all of the edges until you pry up all of the clips. You should be able to pop off the top then. After your done messing with the guts, just straighten the clips and pop the cover back on. Watch out for the smaller pieces when you open it though. There is some padding and the volume button that can come loose if you're not careful.
Posted on Aug 17, 2006
Rio carbon player does not start it reads UPGRADER. I tried resetting needle in hole but still reads UPGRADER
try puting a cf card in it or look up problem on google if this doesnt help hold in menu and power for 4 seconds see if this helps in undoing the upgrader message if not try connecting it to a windows pc with xp or 7
Aug 13, 2011 | Rio Carbon MP3 Player
I turn it on and it says "upgrader" and then turns off. It's done this before and I thought when I hooked it up to the internet or whatever it corrected this problem. I connected it to the computer and the...
This means you are currently in the "upgrader mode". Please turn the unit OFF and then back ON. You can download the latest firmware version of your player. Please be advised that downloading firmware update may delete contents in the memory of your player. You can also Flash the memory by removing the batteries, wait for a few seconds, and put it back in.
If this doesn't work, and if the player is detected by the computer, try to reformat the player (this will erase all the information from the player).
Nov 19, 2009 | Rio Forge Sport Digital Media Player
Rio Carbon Stuck in Upgrader Mode
Hi Allyson,
This is a problem which I have encountered alot with my Rio Carbon.
A solution which always works for me is to hold the player face down in my left hand and then slap the back of it with my right palm a little harder than I would if I was winding a baby.
Best wishes, I hope this works for you as it does for me.
Feb 17, 2008 | Rio Carbon MP3 Player
Plz Hepl Me
Stuck in upgrader mode. Try resetting by inserting a small #1 paperclip in the player. Otherwise, go to the Rio website at realnetworks and download the firmware upgrade.
-Tha Mp3 Doctor
Dec 28, 2007 | Rio CE2100 MP3 Player
Need help with rio forge mp3!! its messed up
Same problem here. No amount of updates or battery removal will help. Purging, re-downloading, reformatting...all failed. I'm afraid at this point there is nothing left to do but toss it.
Mar 29, 2007 | Rio Forge Sprot MP3 Player
My Rio says upgrader when I turn it on
UPGRADER is a mode that purges the firmware from the Rio player prior to flashing the unit. Firmware is basically the operating system for the player, so if it is corrupted any number of things can occur. You can enter UPGRADER mode to update the firmware on your player by holding down the MENU button when you power the Rio ON. Flashing the player in this mode erases all content. Try the following to get the unit out of UPGRADER mode, if powering OFF the unit will not correct it. ALL PLAYERS - If you accidentally entered UPGRADER mode, turn the unit OFF and then back ON again. - Download the latest version of the firmware for your player and upgrade the unit. Visit http://www.digitalnetworksna.com/support/rio - It may be necessary to run the firmware update more than once. - This process may erase content from your player. - If the player is detected by the computer, it is recommended that you format the player, which WILL erase content from the player. - Macintosh user's try flashing the player on a PC. FLASH MEMORY PLAYERS - Remove the battery and replace it, this will reset the unit. The Rio Forge, Rio se510, Rio Cali [Black Rio Stick], and Rio Chiba [Black Rio Stick] can lock up causing the player to be unresponsive. If this occurs there are two things that need to be performed to resolve the issue. First you want to remove power from the player this includes the battery and a USB connection for 20 minutes to reset the player. There is a capacitor on the player that stores a charge that holds the player in the locked state. By waiting the duration the capacitor will discharge and the player should function as normal. Second you will want to upgrade the firmware to the latest version and format the player to prevent future occurrences. HARD DISK DRIVE PLAYERS - If you have a Carbon, Nitrus, Eigen, or Karma, use a paper clip to reset the unit. Your Rio will power off automatically when it has been reset. It may be necessary to connect the player to AC power and then reset the player if it will not turn on. If you are still unable to have the player exit UPGRADER Mode, then try it on another computer. UPGRADE FIRMWARE - Connect to the internet - Go to http://www.digitalnetworksna.com/support/rio/ - Click on the appropriate player - Click on the FIRMWARE tab [showing by default] - Click on the latest firmware file [example: RioForge_firmware_133.exe] - Click SAVE when prompted - From the SA
Feb 14, 2007 | Rio Forge Sport Digital Media Player
Dropped it once and now it's completely unresponsive
I apologize this isn't a solution but I wanted to let you know that I dropped my Rio Carbon player this morning at the gym and now mine won't do anythin either. I reset the player and then I received a display message of 'upgrader." Per the websites instructions i tried to install the most recent 'firmware' and it still does nothing. When it restarts itself it goes right back to displaying 'upgrader' I installed the firmware software a few times per the instructions and still nothing has happened :( I am sad and frustrated at the same time--mine was maybe used a dozen times. I hope we get some feedback to our problem--and again I apologize I didn't post the solution. Jill
Jan 09, 2007 | Rio Carbon MP3 Player
Rio 258 cannot connect to computer
1. go to http://www.digitalnetworksna.com/support/r....asp?prodID=213 and download update 1.33 2. install update in C:\RioForge\Flash133 3. run RioForgeFlash_133.exe from C:\RioForge\Flash133 4. press Rio Forge menu button and turn the unit on. "upgrader" will appear on screen. 5. plug USB cable to RioForge. 6. click "next" on Rio Upgrade Wizard. Wizard will detect your player. Select and click "next". Upgrade will take place. 7. Unplug Rio Forge from USB and turn it on. Voil?!
Oct 12, 2006 | Rio Forge Sport Digital Media Player
The screen says "Upgrader"
Have you upgraded the software if not try that. Check your battery voltage if it reads around the 2. something voltage then you need to get that battery to its orginal capacity. I dont think you'll get your songs back. Does it have a reset button if so reset it.
Jun 10, 2006 | Rio CE2100 MP3 Player
Open Questions:
Rio CE2100 MP3 Player Logo
49 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
