I cannot get internet on my laptop from an open access point with Time Warner internet
I have a laptop by Dell , Inspiron 1525 and my laptop is recieving an internet signal from my nieghbor's internet service provider which is Time Warner Cable (TWC). It is an open signal, does not require a wep code, etc., yet, my laptop shows a strong signal, but, I cannot get online. What can be wrong? Is there a setting I can do on my computer?
  • 596 Answers
Though you are getting strong signals from the router, the router itself may not be connected to the Internet. The owner may leave the router on but power off the modem. It is possible that they may use the router for thier own private network with no connection to the Internet. When you connect to the router, check your network and sharing center to see if you see an X marked on the connection between the router and the Internet. If you do, the router is not connected to the modem.
Good Luck
C2Solutions
Posted on Feb 15, 2012
Limit internet access network
Make sure that the presence of the Internet in the router, restart or
- Switch the device on your computer and open it again
Oct 09, 2013 | Dell Inspiron 1525 Laptop
How do you change limited internet access to full access
Limited access usually means you have full access to your network through your hotspot, but the hotspot is not connected to the internet or it cannot get a signal.
Sep 25, 2012 | Dell Inspiron 1525 Laptop
I cannot get online with my neighbor's internet service. They have an open access signal with Time Warner cable and my message is that I need to renew my ip address to make a connection. I have
To renew the IP address under Windows XP, you issue the following two commands in sequence under command line (aka cmd):
ipconfig /release
ipconfig /renew
Feb 19, 2012 | Dell Computers & Internet
Inspiron 1525 wireless signal good but can't get on the internet
Hi dalemarkie20,
How are you doing? Please try to reinstall the wireless driver of your dell inspiron 1525 to check if that is a driver problem. You can download the wireless driver from support.dell.com.
Hope that helps. Thank you for using FixYa!
Jan 31, 2012 | Dell Inspiron 6400 Notebook
Cannot access internet or no network connection.
Dell Inspiron 1525: Unable to Connect Wireless Network
setting up the right option for wireless network connection at Dell 1525. Here's the following:
  1. Go to Control panel
  2. Select Windows Security Center
  3. Select Windows Firewall
  4. Click on Change settings
  5. Here you might see User Account Control will ask for your permission to continue, simply grant it.
  6. Click on the Exception tab at the middle
  7. Scroll down to Wireless Portable Devices and check the box next
  8. Click Apply, then hit OK
  9. After close the program now you can try to connect again and watch the result.
With assumption you're already make the wireless enable in BIOS setting. In the device manager you should see what the type of wireless wlan card you used and make sure it's already turned on via your switch on your laptop. If it was, then you need to find out the right wireless device driver for Dell Inspiron 1525. Here's the following:
  1. Visit Dell Support site and open the Network tab in the table.
  2. Find your wireless device and download the driver for it.
  3. Aim to a folder on your computer or any external drive if you have it.
At the Inspiron 1525 laptop
  1. go to start
  2. Right click at My Computer
  3. Click Properties
  4. Click Device Manager and Network Adapter .Here you should see a WLAN Mini-Card or might you only see "Unknown Device".
  5. Right Click on it and go to properties to select the Update Driver. Now you should browse the folder to select the driver you're already download at the first step.
NOTE:
Just follow the instruction appears completely. After installation the wireless wlan driver at Dell Inspiron 1525 finish, then reboot the machine and know your wireless connection should be works properly.
Jun 07, 2011 | Dell Inspiron 1525 Laptop
I have a problem with the dvd disk drive on a dell inspiron 1525
Always be sure to close any open programs you do not need to run at that particular time. Also, close your internet connection. The reason for this is to allow the maximum amount of memory to be used by your media software.. Try this. It should work, ok? GOOD LUCK!! Lucky4lynn2
Feb 23, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
Time of day clock stopped - DELL Inspiron 1525
This is one of the known issues with the Inspiron 1525 computer.The problem is caused by faulty cmos battery. If you computer is in warranty kinldy call Dell to get the same replaced . if the system is out of warranty. You would need to replace the CMOS battery ie below the keyboard.
You can follow the instructions below
http://support.dell.com/support/edocs/systems/ins1525/en/SM/coinbatt.htm#wp1179839
Thanks
Proton
Feb 06, 2010 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 webcam wont work with yahoo messenger
This is happening because the Dell webcam central is accessing the webcam at the same time as yahoo messenger. Click on start and click on Run(XP), Type MSCONFIG in start search (Vista) and you'll get the system configuration utility. Open it and go to the startup tab. Uncheck anything related to Dell webcam. Click on Apply and OK and restart the computer. If yahoo messenger shows a black screen uninstall Yahoo messenger and reinstall with the more recent version.
Aug 09, 2009 | Dell Inspiron 1525 Laptop Jet Black
Computer seems to locked up.
The Bios battery is probably dead. It is installed on the motherboard, replace the battery.
May 12, 2009 | Dell Inspiron 1525 Laptop
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
