I have a 32 inch Tevion LCD TV which when turned on the blue light flashes a few times but then goes back to red...help!
SOURCE: lcd not turning on
May i know is it the power led light blinking or just steady?
Posted on Jul 21, 2008
  • 31 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 458 Answers
SOURCE: vertical red line about 3mm wide near centre of
Any fault of this description is normally a fault with the screen. The only way to remedy is to have the screen replaced.
Posted on Jun 30, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
Tv switches on goes from red led to green and after a few second goes back to red. No picture 32 inch aquos
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 30, 2013 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
32 inch sylvania flashes red, blue, black, then white over and over and over, turns on automatically when plugged then goes through these series of colors. need help please
check the main power switch of the TV, then also check the control buttons on the front panel of the TV maybe one of the button s on the front panel is press (normally close state), or maybe the buttons is defective (maybe the menu button)
Jul 22, 2011 | Sylvania LC320SSX 32 in. LCD TV
When i try to turn it on, the light that's red flashes blue a few times and then goes back to red. Nothing else happens.Otherwise the tv runs fine. It's happened before a few times and after a little bit...
That's a classic problem with the Polaroid TVs.
Most of the time it is problem with the power board, but there are a few models - particularily 37'' ones - where the main board goes away.
It will help to know the model of the TV to provide better help, but I bet if you simply google for it you will find the answer yourself.
The 32'' Polaroids from a few years back are *notorious* for this problem.
Bobby, www.coppelltvrepair.com
Mar 15, 2010 | Polaroid Televison & Video
I have a Polaroid flat screen TV 32 inch lcd W Red Light Plz HELP
blown cap in the power supply it will be domed on the top where it vented
Sep 16, 2009 | Televison & Video
My flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
Will not turn on, red light as off, when I push power the red light goes off but
Look for 2 pico fuses in the secondary section of the power supply. I'm sure one of them is blown, that is why the 24 volts are missing.
I will let you know the locations later when I get home.
Good Luck.
Jan 10, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Lcd not turning on
Jul 20, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
