Question about Compaq Presario 700 470024-192 Notebook
I have added 1gb ram transcend while buying laptop ..my laptop doesn't starts alwys in on pressing button once
When i press power on ..all notifiers light goes on but laptop doesn't start i have to close it down aND THEN start again ..it happens 4-5 out of 10 times...or at toimes on restarting my laptop...plz help..i hav added 1gb transcend ram oat time of buying the notebook
  • niwas Oct 26, 2008
    when i press power on ..all notifiers light goes on but laptop doesn't start i have to close it down aND THEN start again ..it happens 4-5 out of 10 times...or at toimes on restarting my laptop...plz help..i hav added 1gb transcend ram oat time of buying the notebook
    Problem Solver:
  • 18 Answers
Don't know if the RAM is a red herring - but try taking it out and see if it makes a difference...
Posted on Oct 25, 2008
Change ram memory compaq presario 2200
1. Do buy the right ram for the laptop such as 512Mb/1Gb So-Dimm DDR PC2700.
2. Unplug the power source and remove the battery as well. Press the power button for 5 seconds in order to discharge all electricity.
3. Open up the ram compartment with the designated screw drivers and replace the old ram with the new one. Make sure the clip of the ram slot is clipping the ram ledge to make sure its installed properly.
Nov 16, 2013 | Compaq Computers & Internet
Msi vr600x won't start.
Remove power unit, battery, RAM and hard drive. Press the power button to discharge any energy that is left.
Insert the power plug and press power. If the laptop goes to the start screen, the motherboard is probably OK. remove the power supply. Add the RAM and repeat. Then do it again adding the hard drive.
There will be a point when the faulty item is identified or it will now boot.
Nov 11, 2013 | MSI MegaBook Computers & Internet
My Dell D600 laptop stopped working today. Coincidentally, I had just turned it off to try running a test on the RAM because the PC had been slow and locking up for the past month or so. Anyway, when I...
try this:
1- deattach the RAM , run the laptop without (RAM) you must hear som beeps
2- put the ram back again in the same slot
if it doesn't work try other slot
Feb 07, 2012 | Dell Computers & Internet
HP Compaq 2510P, 1GB Ram. Power wont come on at all. Pressing power button produces no response at all. Inserting power lead also produces no lights. Have replaced power cord and charger. Battery was...
Try this
Remove the battery from the laptop and unplug it.
Press and hold the power button for 30 seconds.
Reinsert the battery and plug the computer back in.
Try turning it on.
Many HP laptops have a built in static protection that needs to be released. This could be what happened in your case. If this reset doesn't work you will probably need to get it repaired by a technician.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 18, 2011 | HP 2510P U7600, 80GB HARD DRIVE, 2GB...
4 beeps on my Hp pavillion dv6000, blank screen
No Screen on Pavilion DV2000T
I had this problem before. Tere is a good chance this may work.
First of all remove the ram memory.
-remove battery pack and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START. ONCE YOUR SYSTEM IS READY SHUT IT DOWN PUT THE RAM AND BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP.
It hope fully will work as if you get one or more beeps, the POST is completing alright.
Hope that helps.
Dec 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Deactivate ComputerTrace on my Inspiron 1501
Computrace has nothing to do with adding RAM to the system, it merely enables the theft reporting capability of the system (It basically will call home to computrace if stolen)
Should just be as simple as:
  1. Disconnect power and remove battery, then hold power button 10 seconds to release any stored charge in system.
  2. Install RAM at a 30 degree angle till gold contacts completely disappear into slot, then press RAM down till it latches
  3. Power on and enter setup to recognize new RAM configuration, save and exit
If system will not post with upgrade RAM installed then RAM may not be compatible, or BIOS may need to be flashed to current version before installing upgrade modules.
Feb 21, 2010 | Dell Inspiron 1501 Notebook
Changed 1GB RAM to 2GB and now Toshiba Tectra M5 screen is black and HDD doesn't seem to connect! I put the original memory back in, it still doesn't work. Any help would be very appreciated!
It may be the way you are installing the RAM. as a general rule for portables, you install RAM in this manner.
  1. Disconnect power and remove the battery then press and hold power button for 10 seconds to ensure all stored power is drained from the system.
  2. When inserting RAM modules in to the slow, insert them at a 30 degree angle until the gold contacts are completely obscured. Then once fully seated into the slot, press down until the retainers latch.
  3. Connect power and test.
If you changed RAM while power was connected to the system, you may have damaged the RAM modules
Dec 27, 2009 | Computers & Internet
I have added 1gb ram transcend while buying laptop..
hi
this is the virus that preventing your computer on you have to make it formate with master computer
thanks
your friend from fixya!
Oct 26, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
